gearbox drive shaft HELP - Printable Version
+--- Thread: gearbox drive shaft HELP (/showthread.php?tid=57910)
gearbox drive shaft HELP - chaz - 21-03-12
HELP, Has anyone changed the drive shaft on a FZ6 (05) its the one the front sprocket is fixed to or in my case not fixed to, see my other thread "cost of spares".
What I need to know is does the engine have to come out? are special tools required? can the average person do the job and has anyone got a spare shaft going cheap.
What are your thoughts on welding the sprocket (nut) on till next winter/ new chain. which ever comes first?
thanks.
Re: gearbox drive shaft HELP - Fazerider - 21-03-12
It might be dealt with under the warranty:
http://foc-u.co.uk/index.php/topic,92.0.html
But yes, engine needs to come out and I'd describe it as "above average" in terms of DIY difficulty. :lol
Welding the nut should be fine. I did that on my FZS600, even changed C&S by cutting the old nut off with an angle grinder.
Re: gearbox drive shaft HELP - chitsu - 23-03-12
(21-03-12, 04:06 PM)Fazerider link Wrote:It might be dealt with under the warranty:
That article is in reference to the OLD FZS600 and NOT the later FZ6 which the OP has.
Re: gearbox drive shaft HELP - Fazerider - 23-03-12
(23-03-12, 08:07 AM)chitsu link Wrote:That article is in reference to the OLD FZS600 and NOT the later FZ6 which the OP has.
The article lists the R6 and FZ6 models affected. :deal
Re: gearbox drive shaft HELP - chaz - 24-03-12
thanks for the advice, think I'm going for the weld it on method.
Have ordered new chain and sprockets so should be ok for 20 to 30 thou. miles thats 4 to 6 more years.
Re: gearbox drive shaft HELP - chaz - 27-03-12
left the tab washer off put new sprocket on just enough thread to nip it up then mig welded nut to shaft, new chain and rear sprocket, that should do for a few more years?
Re: gearbox drive shaft HELP - Fazerider - 27-03-12
(27-03-12, 12:02 AM)chaz link Wrote:left the tab washer off put new sprocket on just enough thread to nip it up then mig welded nut to shaft, new chain and rear sprocket, that should do for a few more years?
Should be fine so long as the sprocket has no axial play.  :thumbup
