help jacking off or is that up - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: help jacking off or is that up (/showthread.php?tid=57831) |
help jacking off or is that up - BT - 16-03-12 Help please I need a touch more height so thinking jack up kit can they be replaced as in one pair off new ones on or will suspension compress/extend ???really don't want to get into silly problems I once removed crash bars to paint off a BMW GS only to find they would not go back on because the bolts where holding the engine up had to jack the engine up bit of a panick at the time thanks in advance Brian Re: help jacking off or is that up - Fazerider - 16-03-12 So long as the bike's on the centrestand you shouldn't have a problem. Jam a wedge of wood under the back wheel to take its weight as you get the dogbone bolts out, then ease it down a bit to get the new ones to line up with the holes. Re: help jacking off or is that up - BT - 17-03-12 thanks for that ... does anyone sell them on the site ? is 25mm the norm I have seen different lengths but read here it can affect the handling?? any ideas anyone Brian Re: help jacking off or is that up - Fazerider - 18-03-12 Try Fazbaz on here, I know he used to fabricate them to order. Alternatively this lot: http://www.projection-components.co.uk/quad-length-jack-up-links-select-model-18-p.asp do a clever version that offers a choice of lengths. Yes, it will have an effect on handling because the forks will be at a slightly steeper angle. If you find it too twitchy (quite likely if you go for more than a 25mm increase) then increase the front fork preload or fit stiffer springs to compensate. Might be worth doing that anyway if you're on the heavy side. |
