plastic repair to hugger ? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: plastic repair to hugger ? (/showthread.php?tid=57761) |
plastic repair to hugger ? - pitternator - 13-03-12 my plastic hugger has cracked around two mounting points.One bit ha scome off, the other about to do so... I reckon its either fatigue cracks or my dealer overtightened the mounting nuts last year after replacing my rear brake hose , as its only after then that the cracks appeared ...but how do I prove such ? Its an ermax hugger, color coded, so I was wondering if there is anything which would glue the bits back on.? A new one is at least £80 + painting... The pieces are not small, about 30mm across, so I can get a decent amount of glue onto them. any ideas ? cheers Re: plastic repair to hugger ? - chitsu - 13-03-12 Try a local automotive paint/bodyshop suppliers and ask for 'Q BOND' it is a plastic bonding agent and works very well (been using it for years now). Another product if you can get hold of it is called 'MM' it is produced by a company called 'SOL-X' and is a trade only product that is sold to garages & bodyshops only (not sure if you are in the motor trade or know anyone that is?) One thing I will say is it may need reinforcing where you have repaired it, when plastic suffers fatigue/stress fractures they normaly just keep on going to there surrounding areas, ideally you would drill a small hole at the end of each crack & this will stop it continuing. Re: plastic repair to hugger ? - ghostbiker - 13-03-12 You will have an easyer time trying to prove global warming is due to hot air from talk show host's than trying to prove cracked plastics were caused by a shop. I have had a few things where i have been sure they were caused by over/under tight bolts, the normal reply is you should recheck the bolts yourself. I have just repaired the mounts on the tail piece where it bolts to the frame, 1 had a slight crack and the other side had come away compleatly. used a semi ridged dual bond resin i got from toolstaion. seems to be holding well although its only been 750 miles over this weekend so early days. normaly i have used glass fiber on the inside to reinforce plastics. not good looking but adds a lot of strength. Also a few body repair places will offer plastics repair, but i find they tend to be about half the cost of a new item. worth looking in to though, maybe deefer could give you an idea on cost i know he used to or maybe still dose repairs. Re: plastic repair to hugger ? - paul1606 - 13-03-12 mine was the same last year i shaped 2 x bits of plastic & araldited them underneath the split lugs ,and re-driiled the holes through still ok after a couple of thousand miles Re: plastic repair to hugger ? - pitternator - 14-03-12 thanks. I had a word with a mate who is a professional paint sprayer and he reckons it will always be weak after a repair. I found a unpainted new hugger on ebay for £33...so am looking at that option as my mate will spray it for free. I will hang onto the old one and see if it a repair is possible. TBH I like a hugger for its weather protection while touring , as much as the looks...so I do need to get a "working" one back on asap. |
