battery bolts - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: battery bolts (/showthread.php?tid=57697) |
battery bolts - ddtwelve - 09-03-12 well off to charge my battery after it went flat on tuesday and noticed that the positive bolt is actualley a allen key domed bolt, can you get another bolt if so from where and what size? thanks Re: battery bolts - richfzs - 09-03-12 Two free with every battery sold :angel Re: battery bolts - bikerboys - 09-03-12 ebay m8 :lol
Re: battery bolts - ddtwelve - 09-03-12 cheers rich but dont need a new battery just the bolt as the allen key holes are knacked would love to have a philips/hex bolt just in case i break down so i can use the screwdriver in the kit but cant find one on ebay :'( Re: battery bolts - richfzs - 09-03-12 :wall Re: battery bolts - bikerboys - 09-03-12 battery terminal bolts http://www.ebay.co.uk/itm/Pair-6mm-Ford-Battery-Terminal-Bolts-and-Nuts-/170748630606 that sort of thing ? Re: battery bolts - bikerboys - 09-03-12 Normal steel bolts should be fine as long as the metal to metal contact is clean. As always with batteries a little grease on the terminals after you have tightened them is good to prevent corriosion.
Re: battery bolts - rustyrider - 09-03-12 If it's the same as the FZS, the standard bolts are hex with a Philips slot in them anyway. If you can get one out it goes into a square nut under the terminal. Any hardware, motor factors or even B&Q should be able to supply you with a couple of bolts with the right thread. Re: battery bolts - ddtwelve - 09-03-12 yep gonna try local hardware store :rollin Re: battery bolts - richfzs - 10-03-12 all-ye-fucking-yo-lah... its a wee bolt, ferchrissakes... Re: battery bolts - red98 - 10-03-12 screwfix ? Re: battery bolts - Major Rant - 10-03-12 Its a standard short 10mm bolt. I lost one and replaced it with one from my kids swing. They provide a hexagon top with a philips slot just so you can undo it with either tool How thoughtfull eh? .An allen bolt would be OK with me if it was the right length Re: battery bolts - Skippernick - 10-03-12 (10-03-12, 07:49 PM)Major Rant link Wrote: Its a standard short 10mm bolt. I lost one and replaced it with one from my kids swing. Did the swing fall apart??? :rollin Re: battery bolts - Major Rant - 10-03-12 Quote:Did the swing fall apart??? We'll find out on the first warm Saturday of the year.
Re: battery bolts - ddtwelve - 10-03-12 thanks guys went to the local moto x center near by and hey presto two proper battery bolts with nuts for the pricly sum of a smile :lol Re: battery bolts - GringoRojo - 12-03-12 He must've fancied you then. Re: battery bolts - ddtwelve - 12-03-12 nope nice blonde bit behind counter, fiancee wasent too pleased thou right mouthful when we left :rollin |
