Question for them that knows cause i dont - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Question for them that knows cause i dont (/showthread.php?tid=57696) |
Question for them that knows cause i dont - devilsyam - 09-03-12
Re: Question for them that knows cause i dont - Minty - 09-03-12 Just had a look. Float chamber air vent hoses I think, T off between carbs, not sure where they go to though. Re: Question for them that knows cause i dont - devilsyam - 09-03-12 they go behind the block to a square cant see owt coming back out either Re: Question for them that knows cause i dont - Phil TK - 09-03-12 They look like bundy tube so are probably carrying coolant, or in this case coolant to heat the carbs and prevent icing up. Could be wrong tho Re: Question for them that knows cause i dont - sadlonelygit - 09-03-12 Carb overflow pipes for 1+2. Re: Question for them that knows cause i dont - Falcon 269 - 09-03-12 (09-03-12, 10:03 PM)sadlonelygit link Wrote: Carb overflow pipes for 1+2. ... and 3 & 4. ![]() Float chamber vents are the two larger diameter hoses coming off the carbs towards the frame crossmember in front of the battery. |
