Sprocket Cover - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Sprocket Cover (/showthread.php?tid=57539) |
Sprocket Cover - Fuzzy - 27-02-12 After hearing all the scarey stories about Fazers with failing sprocket nuts I thought I'd go check mine just in case. I would have just gone ahead with it as I have done with other bikes, but I had a Haynes manual at hand so thought I'd have a look at that first. Anyway, it said that there is a gasket that needs replacing if you take the sprocket cover off - is this correct? On previous bikes, it's just been a matter of removing the cover, usually plastic, and that's it. All I want to do is check the sprocket nut and shaft - do I need to buy a gasket beforehand or am I getting confused? Thanks! Re: Sprocket Cover - HarryHornby - 27-02-12 there is a gasket. When I removed mine to check it disintegrated in my hands. I bought a new one from Yamaha, think it cost about £6. Re: Sprocket Cover - Fuzzy - 27-02-12 Great, thanks for clearing that up, I'll order one now. Out of interest, do you know why there is a gasket there? Is this common on some bikes? Re: Sprocket Cover - Fazer Jake - 27-02-12 I removed my gasket, couldnt see the need in it :\ Re: Sprocket Cover - Fuzzy - 27-02-12 Yeah, that's what I thought - I can't figure out why it would be necessary there... Re: Sprocket Cover - limax2 - 27-02-12 In some applications a gasket is fitted to stop fretting on the mating faces, but I don't see this as one of those situations. Mine has always stayed intact so is still there, but I tend to agree with Jake that it is not necessary. If you do away with it I would check the clutch adjustment at that case end because you will loose a slight amount of clearance. Re: Sprocket Cover - Mosser - 27-02-12 The only use i can see for gasket on that cover is to stop the grease thats flung off the chain leeching through the join where the gasket is and making a mess on the outside of the bike. My gasket broke into 3 pieces when i took mine off to fit the new nut and washer kit and i just used some hylomar gasket jointing compound, but you could use anything thats to hand, even a bit of silicone bath sealant would do the same job Re: Sprocket Cover - Fuzzy - 27-02-12 Thanks, glad I asked as I was worried it had a more important function. Perhaps it's not worth buying one after all! Re: Sprocket Cover - marksfazer - 28-02-12 I have never replaced the gasket, I like to take the cover every now and then to check my sprocket nut. I don't see the point of the gasket. |
