Plugs & help - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Plugs & help (/showthread.php?tid=57504) |
Plugs & help - Oxygen - 23-02-12 Just taken my plugs out for a clean and they don't have the terminal on the top that goes on the top of the thread. Now as I have no point of reference is this normal . Also iridium plugs or normal ? I hear that iridium are not worth the money for the Fazer ? Re: Plugs - Oxygen - 23-02-12 Better photo http://www.carbibles.com/images/sparkplugparts.jpg Mine just has the bare thread Re: Plugs & help - Fazerider - 24-02-12 So do mine. Mind you, I've NGK plug caps but from memory I'm pretty sure the OEM ones were the same. If you hear the socket clicking over the threads as you push it on you've got contact and so don't need the little screw-on top for the plugs. Re: Plugs & help - Gnasher - 24-02-12 (23-02-12, 11:56 PM)Oxygen link Wrote: Just taken my plugs out for a clean and they don't have the terminal on the top that goes on the top of the thread. Now as I have no point of reference is this normal . Its normal dont worry about it. As for them being iridium thats not standard but ok providing they are the correct range plug, waste of money in my opinion just stick to standard.
Re: Plugs & help - Major Rant - 24-02-12 Re Iridium Plugs ... no idea! but I do have some evidence that "Platinum" plugs are good. I have a 99 Fiesta (Daughter's "Learn to drive" car) with 70K miles on the clock. Plugs last changed at 25K - before I owned it. It developed a misfire. Took plugs out - They are "Platinum Plugs" - and on each bendy electrode is a little circular patch (about 1mm across) welded to the place where the spark hits. That's supposedly where the platinum is. Except .... 1 of the little patches is missing from plug 3!!! (its fallen off) and the electrode has eroded quite a lot. The other plugs look fine. I replaced the eroded plug with a new NGK standard plug ... problem gone. I replaced them all anyway cos I'd bought 4 new plugs. So its not all bollox ... even if I used to think it was. And another thing ... Never use any plug that says "Made in England" on it (some Champions are made in the USA and they are probably OK). :rollin |
