speedo drive and cable replacement - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: speedo drive and cable replacement (/showthread.php?tid=57445) |
speedo drive and cable replacement - markd - 19-02-12 Hi guys and gals just wondering if anyone have replaced there speedo. Drive unit. He so how difficult. is it. Thanks Markd Re: speedo drive and cable replacement - keno - 19-02-12 need to take the front wheel off make sure you take it off backwards not forward the drive is on the left side as if you where sitting on the bike,make sure you do not force anything as the speedo drive lugs will snap just take your time,make sure when replacing the unit that you put the lugs into the slots before putting the wheel back on its an easy job but just take your time and if you have some help will be easier to do. Re: speedo drive and cable replacement - Fazbaz - 20-02-12 (19-02-12, 07:09 PM)markd link Wrote: Hi guys and gals just wondering if anyone have replaced there speedo. Drive unit. He so how difficult. is it. Probably everyone who's ever had a Fazer 600 Baz
Re: speedo drive and cable replacement - markd - 25-02-12 Thanks guys n. Gals anyone know where to get the drive log. Re: speedo drive and cable replacement - Motorbreath - 25-02-12 Are you sure you don't need only the rotor? The rotor bit ref is 5RB-2517G-00-00 (the latest model) 23€ at Yamaha Spain Re: speedo drive and cable replacement - markd - 25-02-12 Not. Sure yet just lookin at options speedo dead thanks Re: speedo drive and cable replacement - DryRob - 06-03-12 any ideas where to get this bit from in the UK? mine's a right mess :o Re: speedo drive and cable replacement - kangastu - 07-03-12 (25-02-12, 04:20 PM)Motorbreath link Wrote: Are you sure you don't need only the rotor? Quote the above part number at a Yammy dealer. I've had to do this before and it was easy to sort. Getting them to find the part number is hard work as a sale of a whole new speedo assembly and sensor is much more profitable. The sensor shouldn't die short of you cutting the wire, but the magnetic cup with the two tabs is easily broken (mostly by quick tyre fitterS!!!) Re: speedo drive and cable replacement - DryRob - 08-03-12 Aye I found one thanks, £17 from my local dealer. I rang some other suppliers but and they charged the same, even a yamaha boat engine shop can get them in, the fella on the phone sounded confused when he got the part description back tho :lol . |
