Givi M11 Plate - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Givi M11 Plate (/showthread.php?tid=57299) |
Givi M11 Plate - Crewpack - 07-02-12 Hi Guys Ive just recently purchased a givi e52 box and I am in the process of getting a givi rack for my fzs1000. I was going to purchase the M5 plate but I have also looked at the new M11 plate, has anybody already had experience of using the M11 plate ? if so is it just as easy to remove the topbox , is it anymore sturdy/secure , what does it look like on the bike. Many Thanks Re: Givi M11 Plate - know your limitations - 10-04-12 I know this reply is two months after your original post but I'll put it anyway in case you're not sorted or if anyone in a similar position comes across this thread. Your box won't fit to an M11 any more securely than the M5 as the important bits (the Monokey mountings) are identical. I have the M5 on my 2002 Gen1 FZS1000 with the E55 Maxia box and it is rock steady. Whilst between Fazers, I also had the use for a couple of months of a Bandit 1250 (you won't tell anyone, right?). This was fitted with the equivalent Suzuki specific, metal monokey plate and I have noticed no difference between the metal and nylon plates in the security of the box mounting. I did a video on Youtube when I installed the Monorack and plate if anyone is interested in how easy it is to do yourself. Fitting a Givi Monorack and M5 Monokey Plate to my Yamaha FZS1000 Fazer 1000 There is also a video of my Givi E55 Maxia top box too here. Givi E55 Maxia NT Top Box. First Unboxing and Fitting Hope this helps you (or anyone else)
Re: Givi M11 Plate - Tanz - 10-04-12 Hello, I got an M11 plate on my Fazer for the sad reality of carrying a laptop on my commute. I never had an M5 but I would say the M11 is a much better fit for the Givi top box than the E43 Givi plastic plate I had on my BMW. No movement at all, unlike the E43 which did move a bit.. |
