Bar end weights - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Bar end weights (/showthread.php?tid=57221) |
Bar end weights - cherokee - 31-01-12 Hi all.I'm new to this forum so please bear with me. Anyone know how to get the bar end weights off? I've tried pushing, pulling and even a heat gun on what looks like glue inside. Only thing this did was to melt the end of the throttle rubber (OOPS). Any thoughts? Thanks. Re: Bar end weights - Bracechenko - 31-01-12 What bike have you got? The FZS600 has allen key bolts so all you need is to stick an allen key in there and unscrew? Think you need 8mm Re: Bar end weights - cherokee - 01-02-12 Sorry, its a '00 fazer 600. What I should have said was Im trying to remove the inserts inside the bars, so I can fit bar end mirrors. Thanks. Re: Bar end weights - DryRob - 01-02-12 I'm thinkin of doin this, where did u get your mirrors? Can you post some pics when you're done please? Re: Bar end weights - serberusno1 - 27-07-12 Any luck on this? Trying to fit handguards and I can't get those inserts out either... Re: Bar end weights - Lazarus - 27-07-12 why dont you throw up a picture of how it looks - ive replaced my bar end weights and also the grips but dont really know what you are referring to. Re: Bar end weights - HarryHornby - 27-07-12 I asked a question similar to this a while back because I want to fill my bars with expandable foam to stem the buzzing, apparently if you peal back the grips, there are 2 clips that you need to depress to remove the internal bit that the bar ends screw into. I've not tried it myself yet because I don't want to pull my heated grips off and brake them, they are stuck fast to the bars. Re: Bar end weights - JZS 600 - 27-07-12 Mirrors on the end of the bars? Jesus, you would be able to see F- all most of the time! Re: Bar end weights - Lawrence - 28-07-12 If you get those inserts out can I have on please? Got rid of the bar end mirrors when I put the faring back on (before I even rode it) and got no weights as one side is missing the thing to screw it into.
Re: Bar end weights - misterjayb1 - 29-07-12 Not sure i'd get my Fazer thru the gate with bar end mirrors.. jeez they make the bike wide n 4 mirrors would be 2 too many for me :rollin Re: Bar end weights - bikemad62 - 09-08-12 I have 1 bar end mirror on the left hand side and no blind spot for scooters and officers of the law to hide in. :lol |
