Luggage width advice - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Luggage width advice (/showthread.php?tid=57200) |
Luggage width advice - Easy Rider 13 - 30-01-12 just wanted to know if there is a legal limit to how wide you can have your luggage panniers? i know general rule is about the same as your mirrors but i have the missus on the back and cant use the seat so have to go out a little wider? The weight of it all is fine just need to know im not going to get pulled or told off etc? i'll add pictures in a second post as they wont add properly :\ Re: Luggage width advice - ghostbiker - 30-01-12 a google might come up with the answer but i know there is a rule about there has to be a rear light within a set distance of the widest part of the bike, its a rule i became aware of when dabling in trike building years ago. i doubt it would effect luggage as it was quite wide. there would be a law on if it was fully secured and not unsafe(unsecured/unsafe load) but i would imagin it would have to be fairly extream to pull attention from the police. Re: Luggage width advice - Easy Rider 13 - 30-01-12 ive had a look online and all i can find is that it changes the handling and it affects when filtering? do i take this as i'll be ok? Re: Luggage width advice - Grahamm - 30-01-12 (30-01-12, 04:08 PM)Ton13 link Wrote: i know general rule is about the same as your mirrors but i have the missus on the back and cant use the seat so have to go out a little wider? Are you saying your missus has a fat bum?! ![]() The Givi panniers I have on my FZ6 are wider than my mirrors, so I just have to keep that in mind if I try to filter, but unless you've gone for something ridiculous, I doubt you'd have problems. You could always check the width of a Pan or a Goldwing... |
