Stainless nuts and bolts. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Stainless nuts and bolts. (/showthread.php?tid=57108) |
Stainless nuts and bolts. - davec - 22-01-12 Any ideas on the best place to get Stainless nuts and bolts from? Re: Stainless nuts and bolts. - bagnall18 - 22-01-12 ebay type in fzs600 probolt there's loads of stuff and different colours
Re: Stainless nuts and bolts. - Gnasher - 23-01-12 If it's just engine and other non stressed areas you want the bolts for look on ebay for bolts by the bag you can get 100's for the price of 20 from Probolt, they are very very expensive try these: - http://www.ebay.co.uk/itm/370287148580?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 http://www.a2stainless.co.uk/Japanese_B2142Y.aspx https://secure.hosts.co.uk/~custom-fasteners.co.uk/acatalog/Fasteners.html If you want stressed area bolts/nuts i.e. caliper mounting, fork pinch bolts then you need to ensure you get thr correct grade of SS. Re: Stainless nuts and bolts. - davec - 23-01-12 Thanks for your replys.I am looking for rear caliper torque arm bolts and rear caliper bolts so they are going to be stressed. What would you recommend as a good stress grade stainless steel?Thanks. Re: Stainless nuts and bolts. - Lumpy - 23-01-12 Look at other suppliers such as Namricks. Do a search on the internet there are loads around. Pro-Bolt is very top end stuff. A4 is the best grade, A2 is harder but not as corrosion resistant. A4 bolts should be fine for what you want them for, and A2 as well. Re: Stainless nuts and bolts. - davec - 23-01-12 Thanks again,info much appreciated. Re: Stainless nuts and bolts. - Pat - 24-01-12 I've used this company a few times over the years for stainless bits & always found them reasonably priced with good quality & service - http://www.inoxbolt.co.uk/ Re: Stainless nuts and bolts. - griff86 - 24-01-12 http://www.shinybikesyndrome.co.uk/cms/index.php/our-products/pro-bolt-tasty-nuts Check out Nooj who is a member on this site, this is his website, I'm sure he gets a certain percentage off pro-bolt. Re: Stainless nuts and bolts. - bikerboys - 29-01-12 Can any one tell me the bot size for the handlebars for my fzs 600 98 thanks as these are staring to rustand would like to get some stainless ones thanks
Re: Stainless nuts and bolts. - bikerboys - 07-02-12 :\ any one give me what size I need please Re: Stainless nuts and bolts. - Gnasher - 07-02-12 (07-02-12, 10:25 PM)bikerboys link Wrote: :\ any one give me what size I need please 8M about 50mm long off the top of my head. Re: Stainless nuts and bolts. - limax2 - 08-02-12 The four cap head screws for the handlebar clamps are M8 x 30mm long. (FZS600) i.e. 30mm from under the head to the end of the screw. Re: Stainless nuts and bolts. - bikerboys - 08-02-12 (08-02-12, 09:41 PM)limax2 link Wrote: The four cap head screws for the handlebar clamps are M8 x 30mm long. (FZS600) [size=0.7em][/size]thank you just order some stainless steel ,marine grade them buggers not rust[size=0.7em] [/size] :rollin
Re: Stainless nuts and bolts. - Juliofantastico - 12-02-12 Got Titanium set of nuts and bolts from Probolt. |
