What to buy? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: What to buy? (/showthread.php?tid=57037) |
What to buy? - Fazer Jake - 15-01-12 Looking to spend a few hundred quid on my fazer after an insurance payout from my old bike... decided not to part with it for a more pillion friendly bike. ![]() So it has... Rear Hugger K&N Exhaust radiator cover Unsure on what to buy, i was thinking a new can, aftermarket fairings (any idea where i can get these?) and a jackup kit, possibley braided hoses (do they make much of a difference? Advice welcome/pics of your mods to persuade me! Re: What to buy? - wraith600 - 15-01-12 braided hose def those std ones will be near the end of there life fazer1000 rear calaper as the stock one is crap stiffer fork springs with 15 or 20 weight oil dont wory about the rear till you get the front end sorted as its a bit under sprung & damped . if you still need it to steer faster drop the yokes 10mm .try a fazer1000 shock on the rear Re: What to buy? - Fazer Jake - 16-01-12 will a standard thou shock fit a foxeye easilly? Re: What to buy? - wraith600 - 16-01-12 found this on the old site [color=rgb(255, 255, 255)]"I finally got hold of a thou shock at a reasonable price,now fitted to my 02 600 foxeye , it works a treat, to the point where the rear suspension is forgetable, before I had pogo effect when pushed hard , Now twisty bumpy roads are a much more pleasant experience, Fitting involves swapping the 600 spring onto the thou shock, for this you will need a spring compressor "can be done with big jubilee clips" an angle grinder and a bench grinder is usefull. the spring collet retaining washer on the thou shock needs to be reduced in diameter also plastic spring seat reduced, "bench grinder" also the spring tension adgusting bracket will have to be ground away "angle grinder" on the side away from the gas can ( otherwise it will wear away the coolant overflow tank) I set my shock spring at one click from softest . For my weight 10st this is perfect pre load .Then I moved the said coolant tank to the backside of the mounting on the nearside of the bike "same reason" This is a bit fiddly you may have to devise a retaining clip . no big deal as it is still mouted firmly on the otherside of the bike and there is no weigh/load on the tank . apart from setting the rest of the shocks adjustements to medium that is it. The adjustment on the spring is now fiddly but no more adjustment seems necessary.best mod since home made vario"[/color] another option get in touch with devils yam about an R6 shock mod this would probably be easer Re: What to buy? - Fazer Jake - 16-01-12 sounds tricky :eek just bought some wezmoto braided hoses Re: What to buy? - Fazerjon - 17-01-12 Whats the quality of the Wezmoto braided hoses? I was looking at those and wondering..... :rolleyes Re: What to buy? - adeejaysdelight - 19-01-12 Braided hoses are great. Fitted them to every bike I have owned, including my CBF125 Re: What to buy? - Fazerjon - 19-01-12 Ive fitted Goodridge and HEL Stainless brake pipes to other bikes, just wondered if the 'Wezmoto' ones are as good.
Re: What to buy? - Fazer Jake - 21-01-12 (19-01-12, 01:56 PM)Fazerjon link Wrote:Ive fitted Goodridge and HEL Stainless brake pipes to other bikes, just wondered if the 'Wezmoto' ones are as good. Fitting the Wezmoto hoses today, they are great, seem like good quality. Only draw back was no cable tie in the kit. Re: What to buy? - Skippernick - 22-01-12 It will be good to know how you get on with these. Question on there description on the ebay site, they say two break lines to replace the front ones, where as my bike and i assume many others has one line to a t-piece and then two lines down to the caliper therefore 3 lines. does this mean you run both from the master cylinder direct to the calipers, bypassing the t-piece? cheers Re: What to buy? - Fazer Jake - 22-01-12 (22-01-12, 10:45 AM)Skippernick link Wrote:It will be good to know how you get on with these. Yeah thats right, they supply a longer nut so two hoses fit to the master cylinder. Re: What to buy? - donkey93 - 22-01-12 2 bolts from my hel kit which i got yesterday Re: What to buy? - Skippernick - 22-01-12 (22-01-12, 10:54 AM)Fazer Jake link Wrote:[quote author=Skippernick link=topic=1385.msg10563#msg10563 date=1327225518] Yeah thats right, they supply a longer nut so two hoses fit to the master cylinder. [/quote] Ok thats great thank you for the info. Sounds like my next upgrade if they are up to standard. cheers Re: What to buy? - Fazerjon - 23-01-12 Yeah I reckon I'll give them a go too
Re: What to buy? - thom_1991 - 23-01-12 Best/most cost effective improvement i made was to get linear springs in the forks. For 11 stone me with occasional track days .90kg/mm rating (i think) is spot on. Of course then the shock will feel distinctly average... Re: What to buy? - CharlieDee - 24-01-12 Ordered my braided lines and reconditioned rear caliper today.... looking forward to having some brakes!! :rollin Re: What to buy? - Fazerjon - 25-01-12 where did you order your brake lines from? Did you order 2 front and one rear, with stainless steel fittings too? Just looking for best deal at the moment
Re: What to buy? - CharlieDee - 25-01-12 Good old Ebay... went down the Goodridge route... Item number 270786814672 - Cheapest Gooodridge front set on the site & Item number 290644425172 - for the rear :rollin looking forward to test riding the beast now!! my fazer has been getting a right treat this week!! Renthals/Motrax Grips/New rear Caliper with EBC HH Sintered pads & Goodridge all round... just need that stainless downpipe set now!! :lol
Re: What to buy? - Fazerjon - 26-01-12 Cheers for that, I'll have a look. Enjoy your new brakes....
Re: What to buy? - Tourx4 - 23-02-12 @Fazer Jake I adore your fazer, i want one like that in blue but if i can't have it, i'll have it in silver or sunshine yellow!!!
