gauge - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: gauge (/showthread.php?tid=56954) |
gauge - tex - 07-01-12 hi, Does anybody know of a good motorcycle elecy or shop, to fit a multi gauge and white dials, I live in the north london, herts essex area. But dont mind traverling a bit. Tex Re: gauge - Silverdream - 07-01-12 Hi... Fitting a multigauge?? which one? Excellent write up of Christians multigauge installation here... http://www.cartestsoftware.com/fz1/multigaugeinstallation.html have a go yourself and then while you are doing that it should be quite easy to fit the white dials... Jobs an easy one and you save yourself a load of dosh...!!! Silverdream Re: gauge - tex - 08-01-12 Thanks silver, the gauge came from christian, so i have the instructions. Never done anything like this ,so did not want to screw it up, can do the basics, I will have a good read and might have a go. tex. Re: gauge - paul1606 - 08-01-12 the soldered connections are a bit fiddley , if you,ve dodgy eyesight like me i found it easier doing it with a magnifying glass and before the smartarse answers a soldering iron. But if you do cock up you can use a solder sucker to remove & start the joint again Re: gauge - tex - 19-01-12 Thanks paul |
