problems with pyramid hugger fitment on gen1 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: problems with pyramid hugger fitment on gen1 (/showthread.php?tid=56817) |
problems with pyramid hugger fitment on gen1 - fazer6868 - 18-12-11 Anyone had problems with the above? My gen 1had a pyramid hugger for around 80k, howver itwas always 'twisted' in that it sat higher on one side than the other even after building up the brake side with spacers. i eventually had to bin it when it fell apart. after trying to find some other makes i bought another pyramid thinking that i won't have the same problem and bugger me it's worse. again on the brake side the hugger is touching the tyre and there is insufficient gap betweek the fornt part and the ceoss bar on the swing arm. Re: problems with pyramid hugger fitment on gen1 - bludclot - 18-12-11 i fitted a skidmarx hugger to mine. i binned the supplied fittings, measured exactly where i wanted it to sit and made up my own mounting bracket for the brake side. i figured it was either that or suffer a lopsided hugger... Re: problems with pyramid hugger fitment on gen1 - cable tie - 18-12-11 I brought a pryamid hugger for gen1 about 4-5 months ago in the blue colour and mine fits perfect, i also run 6'' rear wheel with 190/50 tyre and the gap between hugger and tyre is fine, sounds like i may have struck lucky as im sure someone else on the site had complained about there hugger as well !! Re: problems with pyramid hugger fitment on gen1 - The Male Whale - 19-12-11 I was the other guy! Mine was a Red Fox though. Problem was simple on mine - holes drilled in wrong place. Red Fox replaced mine and I gave the old one away to soeone on here who reamed out the holes and bolted it up! |
