Mirror extenders for fzs 600 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Mirror extenders for fzs 600 (/showthread.php?tid=56746) |
Mirror extenders for fzs 600 - allclaret - 09-12-11 Anyone know of any products available for extending mirrors on a 99 fzs 600 ? Also same problem on my summer toy an 08 fz1s. Any help will be gratefully received . Cheers ian Re: Mirror extenders for fzs 600 - limax2 - 09-12-11 If you still have the original mirrors on the easiest way would be to fit the later mirrors as used on the fox eye model. i.e. 2002-2003. They have a longer stem. Made a big difference for me. Re: Mirror extenders for fzs 600 - allclaret - 09-12-11 Cheers will look out for a set Re: Mirror extenders for fzs 600 - DryRob - 09-12-11 I'm thinking of putting a set of bar end mirrors on mine, might be an option for you Re: Mirror extenders for fzs 600 - Slaninar - 11-12-11 Here, someone ought to put this on a sticky, or something: http://www.louis.de/_206df5cbb4e9c0ef05dc285e1718bd64ef/index.php?topic=artnr_gr&article_context=detail&grwgr=465&wgr=404&list_total=27&anzeige=0&artnr_gr=10028310 Louis always has these cheap, aftermarket FZS2002+ mirrors. They fit bolt on and are nicely some 5 cm wider - just perfect. Nice for filtering, but you can see past your shoulders. Re: Mirror extenders for fzs 600 - born to be mild - 20-12-11 Would these fit my 1998 model ? Im sick of admiring my elbows at 70 mph. Re: Mirror extenders for fzs 600 - limax2 - 20-12-11 (20-12-11, 06:20 PM)born to be mild link Wrote: Would these fit my 1998 model ? Im sick of admiring my elbows at 70 mph. Yes. I seem to remember (but could be wrong!) that the 6mm mounting studs are slightly longer on the 02-03 mirrors. If they are longer it's not enough to cause the domed nuts from the 88-01 model to bottom out. Re: Mirror extenders for fzs 600 - born to be mild - 21-12-11 Cheers for that Limax, i can always nip a bit off them if its a problem and also thanks for the Louis link, Slaninar. Re: Mirror extenders for fzs 600 - Slaninar - 21-12-11 (21-12-11, 09:56 AM)born to be mild link Wrote: Cheers for that Limax, i can always nip a bit off them if its a problem and also thanks for the Louis link, Slaninar. You're welcome. They fit on square eyes no problem. A bit longer nuts, but who cares? So far they've put some 20,000 km in 180+ km/h speeds, bumpy roads, hot, cold - no problem. They are still standing like I put them. Decent quality IMO. At that price - it's a no brainer. Re: Mirror extenders for fzs 600 - His Dudeness - 22-12-11 i have the same problem seeing my elbows in the original mirrors. but does putting the wider mirrors on make filtering trickier? easy filtering is probably the best thing about the fazer. i wouldn't want to lose that Re: Mirror extenders for fzs 600 - Slaninar - 23-12-11 (22-12-11, 08:05 PM)His Dudeness link Wrote: i have the same problem seeing my elbows in the original mirrors. but does putting the wider mirrors on make filtering trickier? easy filtering is probably the best thing about the fazer. i wouldn't want to lose that Compared to my Suzuki GN125, these are still ultra narrow. Those additional 5 cm to each side are higher than most car mirrors, so no problems there. They are plastic, won't scratch car paint even if you do touch anything. In my case mirrors are practically not wider than my rear topcase, so another warning - mirrors don't pas, I don't pass. :eek These spill check is rally good!
Re: Mirror extenders for fzs 600 - sicknote - 23-12-11 Got a secondhand set of aftermarket mirrors for my 99 fzs off the bay recently, don't know the brand, they are alloy castings adjustable for extension and feature cute diamond shape mirrors though really only the far corner is useful when sat up. the extension really needs to be a bit more but they are all round tastier than stock mirrors. :thumbup |
