Warning lights? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Warning lights? (/showthread.php?tid=56724) |
Warning lights? - Fazer Jake - 06-12-11 Started my fazer 03 the other day put the lights on then i pressed the pass switch and both the engine oil warning light came on and the coolant levelĀ :rolleyes Re: Warning lights? - bikemad62 - 07-03-12 Mine did that about a year ago. mine was a corroded block plug and a loose earth strap. split each block plug, spray generously with wd40 put back together. Repeat this with every plug and do the same with the battery terminals. hope this helps. |
