Removing the Carb De-Icing Hoses - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Removing the Carb De-Icing Hoses (/showthread.php?tid=56636) |
Removing the Carb De-Icing Hoses - PieEater - 25-11-11 Now that I've got rid of the AIS from my Gen1 I'd like to get clean up a bit more and get rid of the 2 hoses feeding the de-icing circuit between the carbs and the radiator. I don't ride the bike if the thermometer is going to read less than 10c so I can't see this being a problem. I was thinking about trying to source some caps for the spigots on the radiator and thermostat housing to blank them off but then thought that it might be easier just to run a pipe between the two so in effect the circuit remains (albeit a lot shorter) but the carbs are bypassed. What I didn't want to do was put any additional stress on the water pump and just thought I'd ask here for any comments. Re: Removing the Carb De-Icing Hoses - Falcon 269 - 25-11-11 Pat's Site: http://www.cartestsoftware.com/fz1/carbcoolantbypass.html The oracle. ![]() Read right to the end. Ignore Pat's thing of capping off the spigots and follow the guide to re-using the existing hose to bridge the radiator/thermostat housing. Mine's been like that for 6 years now. ![]() Simples! Re: Removing the Carb De-Icing Hoses - PieEater - 25-11-11 Thanks Mike - The photo shows the pipe with an inline filter / valve, is this neccesary or would a straight hose do? Perhaps the spigots are different circumferences so the original pipe has been shortened with the filter / valve left in place. Re: Removing the Carb De-Icing Hoses - solorider - 25-11-11 i read something on the net a while a go and you can get carb icing at a temerature as high as 10 degrees as the air going into the carbs is usualy a lot lower in temp so be warned if you have problems Re: Removing the Carb De-Icing Hoses - Falcon 269 - 26-11-11 (25-11-11, 11:05 PM)PieEater link Wrote: Thanks Mike - The photo shows the pipe with an inline filter / valve, is this neccesary or would a straight hose do? I used the original hose because it fitted correctly and was free. The inline valve isn't essential, though.
