Header pipe brackets - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Header pipe brackets (/showthread.php?tid=56472) |
Header pipe brackets - ridgemere - 07-11-11 I've got my down pipes off to sort out the e?@& valve and while they we're off give them a good clean. Managed to get them sparkling again but the header brackets look a right mess! These can't be replaced so I'm looking for cleaning tips so they match my sparkling pipes. Cheers Re: Header pipe brackets - solorider - 08-11-11 im about to do mine,i have sliced some toilet roll inner tubes which slide inside them nicely and hold the pipe brackets in a ideal place to make it easy to paint them,im going to use a dremel to remove the rust on them then use some heat resistant paint to tidy them up,and i have some nice stainless steel cup nuts and lock washers to bling them up a bit more |
