R6 clocks on fzs. has it been done?? how?? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: R6 clocks on fzs. has it been done?? how?? (/showthread.php?tid=56453) |
R6 clocks on fzs. has it been done?? how?? - sjdfzs - 06-11-11 ive seen a pic somewhere on google of a fazer with r6 clocks and i thought i would do the same. a lot of the colours are the same so ive tried connecting them but cant get it all working. ive managed to get rev counter working but not right, indicators, full beam and neutral lights but not speedo, fuel or temp can anyone help? Re: R6 clocks on fzs. has it been done?? how?? - Deefer666 - 06-11-11 I cant see the point of this mod, if it purely for looks then surely a Vaypor or similar data-logger type dash would look better. I dont think you will ge it to work correctly as the impulses and signals from the CDI will be complete different. Re: R6 clocks on fzs. has it been done?? how?? - sjdfzs - 07-11-11 when i got the bike it was a wana-be stunt bike, day time MOT, no lights only brake light, no clocks, no fairing, engine crash bars and a 12 o'clock bar.62 tooth rear sprocket! im turning it in to a streetfighter and thought it was a nice smart clock from same year, same make and does the same things but i wasnt sure but ive had a quick go but had enough now and waiting for a universal 1, is there a gallery on here of all the mods n bikes? Re: R6 clocks on fzs. has it been done?? how?? - Deefer666 - 07-11-11 Just do what I do with my fighters and fit the cheapest nastiest digi-push bike speedo, most read up to about 60ish (after that you are pretty much speeding anyway) The R6 clocks would look pretty but I dont think they are gonna work. Re: R6 clocks on fzs. has it been done?? how?? - sjdfzs - 08-11-11 i've ordered this one now, worked out £56 http://www.ebay.co.uk/itm/110753135414?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_2453wt_922 Re: R6 clocks on fzs. has it been done?? how?? - sjdfzs - 08-11-11 its a copy of http://www.digital-speedos.co.uk/rx1n-multifunction-black-dial-white-backlight-117-p.asp Re: R6 clocks on fzs. has it been done?? how?? - Deefer666 - 10-11-11 I have one of these to use on the next project Re: R6 clocks on fzs. has it been done?? how?? - wraith600 - 14-11-11 (07-11-11, 07:42 PM)sjdfzs link Wrote: when i got the bike it was a wana-be stunt bike, day time MOT, no lights only brake light, no clocks, no fairing, engine crash bars and a 12 o'clock bar.62 tooth rear sprocket! im turning it in to a streetfighter and thought it was a nice smart clock from same year, same make and does the same things but i wasnt sure but ive had a quick go but had enough now and waiting for a universal 1, no real gallery but whats your wallet / imagination like once you start modding it's slippery slope :rollin and you will never get your money back :lol hears mine http://s1124.photobucket.com/albums/l568/wraith600/ link to old site http://fazerowners.yuku.com/topic/32785/my-600#.TsGZuMO5Pdw Re: R6 clocks on fzs. has it been done?? how?? - sjdfzs - 15-11-11 :eek def 1 of kind Re: R6 clocks on fzs. has it been done?? how?? - wraith600 - 17-11-11 yep :evil Re: R6 clocks on fzs. has it been done?? how?? - sjdfzs - 20-11-11 anyone know... where the wire is for the oil light? how to get my fuel and temp gauges to work as theres only 1 wire for each of them on my clocks or what wires they use on the yamaha clock loom wraith600 you should know this! Re: R6 clocks on fzs. has it been done?? how?? - wraith600 - 20-11-11 the brown wire in the clocks is a common live used by most of the assorieys in the dash on the fazer and must be connected green for the fuel gauge green / red for fuel warning light green /white for engine temperature warning light with out a wiring diagram for the correct r6 ? as the pickup on the r6 & fazer is diferant getting the r6 speedo to work will not be easy and i cant help there Re: R6 clocks on fzs. has it been done?? how?? - sjdfzs - 20-11-11 thanks. i gave up on the r6 one and just got a universal one http://www.ebay.co.uk/itm/110753135414?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_2453wt_922 ive used a + from elsewhere, do you think thats why the fuel and temp gauges wont work? Re: R6 clocks on fzs. has it been done?? how?? - sjdfzs - 20-11-11 also what one is the oil light? thanks Re: R6 clocks on fzs. has it been done?? how?? - solorider - 20-11-11 In theory anything can be done,so long as the original bike does not use the ecu for the info,like Honda did with the later blackbird,a few years a go I fitted a set of gpz900 clocks to my Yamaha xj750 and they work with no issues.you need to check the wiring diagrams on bothe bikes and most wires should be like for like on a Yamaha ,as to the speed sensor if there is an inaccuracy then a speeo healer should fix the problem Re: R6 clocks on fzs. has it been done?? how?? - sjdfzs - 21-11-11 thats what i thought but just thought it would be easier to just get a universal one, its only £56 and looks really smart, better than the r6. ive got most of it fitted. made the bracket out of 3-4mm ali just need to heat it it and put a bend in it, rev counter works but not quite right so need to look into that, dash lights done just need to... make a mount for speed sensor work out how to wire up the fuel gauge same with temp find the wire for oil light well thats the clocks anyway. fitting a standard rear sprocket later today, abit scatty with the big one, if you dont sit forward it wheelies n spins if you do :lol |
