clutch question - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: clutch question (/showthread.php?tid=56084) |
clutch question - solorider - 04-10-11 i need to buy some new clutch plates so is it worth buying heavy duty springs or am i better off sticking with a set of genuine springs? Re: clutch question - scousy - 04-10-11 if it helps i asked the same quetion to the guys at Bike Torque Racing Ltd and they said standard springs are fine , that was with a Surflex clutch kit which is allegedly much better than an OE clutch ? Re: clutch question - solorider - 05-10-11 im going to be hetting a ebc clutch plates,the surflex plates are a bit over my budget at the moment I have just fitted a completly new clutch - b1k3rdude - 05-10-11 my suggestion, get stock springs (as the pattern springs make the clutch action noticeably heavier) and the other thing I found was the pattern friction plates screwed up the biting point, but this may have been an issue with the thickness of the pattern plates all being 3mm when compared to the oem have a 4 at something like2.5mm and the rest at 3mm etc. Re: I have just fitted a completly new clutch - solorider - 05-10-11 (05-10-11, 04:35 PM)b1k3rdude link Wrote:my suggestion, get stock springs (as the pattern springs make the clutch action noticeably heavier) and the other thing I found was the pattern friction plates screwed up the biting point, but this may have been an issue with the thickness of the pattern plates all being 3mm when compared to the oem have a 4 at something like2.5mm and the rest at 3mm etc.i would love to get a genuine clitch,but i cannot afford the cost of it at £159.57 plus the cost of the springs. it is possible that my bike may already have a pattern clutch as the biting point is near the end of the lever travel Re: clutch question - b1k3rdude - 06-10-11 My previous thou's never needed to the clutch replacing, so can't say for sure. All I can say is with the pattern plates/springs in in the brand new clutch & boss, the cable adjusted to there was virtually no free-play, the biting point was 1.5-2" away from the bar! Re: clutch question - solorider - 06-10-11 (06-10-11, 01:22 PM)b1k3rdude link Wrote:My previous thou's never needed to the clutch replacing, so can't say for sure. All I can say is with the pattern plates/springs in in the brand new clutch & boss, the cable adjusted to there was virtually no free-play, the biting point was 1.5-2" away from the bar!that is how mine is at the moment Re: clutch question - mike26 - 07-10-11 STANDARD SPRINGS!!! i have HD clutch springs and now i also have a pretty strong left hand Re: clutch question - b1k3rdude - 07-10-11 (06-10-11, 04:54 PM)solorider link Wrote: [quote author=b1k3rdude link=topic=429.msg2336#msg2336 date=1317903765]that is how mine is at the moment [/quote] Hmmm, you could try the pattern plates with your old springs, as long as the springs aren't shorter than 50mm they can be reused. |
