Rev'Counter Going Wacko Jacko - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Rev'Counter Going Wacko Jacko (/showthread.php?tid=55937) |
Rev'Counter Going Wacko Jacko - Fuzzygoth - 26-09-11 My Rev Counter on my 04 Fazer 1000 when I turn the ignition before starting the engine it shoots up to 7k rev's for 2 seconds every 6 seconds until I start the engine and then everything is normal. Anyone know what going on with it is it an error or fault in the wire? Fuzzy Re: Rev'Counter Going Wacko Jacko - steeeve66 - 26-09-11 that looks like an EXUP that needs seeing to - could be the valve itself or just the pulley that's seized or just that the cables need adjusting, others here on the site will know better than me... Re: Rev'Counter Going Wacko Jacko - PieEater - 26-09-11 Yup that's the EXUP fault code, have you serviced the EXUP recently? Incorrectly tensioned EXUP cables or a stuck valve is probably your cause, have a look here - http://www.cartestsoftware.com/fz1/exupmaintenance.html Re: Rev'Counter Going Wacko Jacko - The Male Whale - 27-09-11 A good thrapping can usually free off a slightly sticky valve. On the Gas! top
Re: Rev'Counter Going Wacko Jacko - locksmith - 27-09-11 Been a long time since I had one, but doesn't the needle do the 7k thing while the engine is running as well? Re: Rev'Counter Going Wacko Jacko - steeeve66 - 27-09-11 ..it didn't on mine, others here may have a different experience tho Re: Rev'Counter Going Wacko Jacko - Falcon 269 - 27-09-11 (27-09-11, 07:18 PM)locksmith link Wrote: Been a long time since I had one, but doesn't the needle do the 7k thing while the engine is running as well? Yes, tacho reads actual revs for a few seconds, then the fault code, then zero, then back to actual revs. Re: Rev'Counter Going Wacko Jacko - nickodemon - 27-09-11 (27-09-11, 07:18 PM)locksmith link Wrote: Been a long time since I had one, but doesn't the needle do the 7k thing while the engine is running as well?I had the same fault with a fazer i bought recently, but after the ride home it freed off. (rev counter fault code stopped) The bike hadn't been getting used for a few months, so it was just a bit sticky. Its worked fine ever since. Usually its best to strip down, give it a good clean and regrease (coppper grease), rebuild it and adjust the cables. |
