Scots only folder - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bits and bobs (https://foc-u.co.uk/mybb/forumdisplay.php?fid=67) +--- Forum: The Laboratory ! (https://foc-u.co.uk/mybb/forumdisplay.php?fid=83) +--- Thread: Scots only folder (/showthread.php?tid=55756) |
Scots only folder - Aegis Bearing Mel - 03-01-11 In theory, the only ones who should be able to post are Mike, Gringo, Raymy and Andrew. Frazer, I've tried to block you from seeing it, has it worked on your Eye of Providence? Can other peeps try to post a photie to it please? Cheers. Aegis Re: Scots only folder - Farjo - 03-01-11 Hi, admin and Global Moderators can access everything so I added Dan Lewis to the block list, and indeed he can not see the album at all. Then when I remove him from the 'denied' list he can see the pictures but there is no Upload button. Well done :thumbup Re: Scots only folder - Aegis Bearing Mel - 03-01-11 This place really is wysiwyg, magic.
Re: Scots only folder - Andrew - 03-01-11 Yep I added a pic :woot Re: Scots only folder - Farjo - 03-01-11 Bloody sweaties :fish Re: Scots only folder - Aegis Bearing Mel - 03-01-11 :woot Re: Scots only folder - Grahamm - 03-01-11 Up yours, haggis bashers!! :rollin Re: Scots only folder - Grahamm - 03-01-11 A follow up: I thought I could post to it, but it seems I can't, however I can still view the folder. Re: Scots only folder - Aegis Bearing Mel - 03-01-11 Double :woot Was thinking that it means event organisers could create a folder for photies for said event and limit who can post to it. Should keep random photies from appearing, also reduce the chance of spamming by outside agencies meaning stuff gets lost. Allows folks to see what went on at Foccer meets without adding random keech. If it would be worth the effort or not is an entirely different argument, but I'm glad the theory works.
