New Chain Time = Sprockets too ? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: New Chain Time = Sprockets too ? (/showthread.php?tid=80727) |
Re: New Chain Time = Sprockets too ? - bandit - 29-04-19 (29-04-19, 05:33 PM)fazersharp link Wrote: Also going to need some loctite 620 for the front sprok I would & have used blue 243 loctite as this locks & is easier if removal is required in the future. Re: New Chain Time = Sprockets too ? - fazersharp - 29-04-19 (29-04-19, 06:00 PM)bandit link Wrote: [quote author=fazersharp link=topic=25205.msg297201#msg297201 date=1556555616] I would & have used blue 243 loctite as this locks & is easier if removal is required in the future. [/quote]That is cheaper and can get in smaller bottles but the official OEM maintenance guide says 620. I think partly as 620 is heat resistant as well as being Focing strong Re: New Chain Time = Sprockets too ? - robbo - 29-04-19 The longer the breaker bar the better. As suggested if you're not in a tearing hurry ebay would be your best bet. Re: New Chain Time = Sprockets too ? - darrsi - 29-04-19 I use a 1.5" piece of aluminium scrap tube I found at work years ago, works a treat for leverage. Re: New Chain Time = Sprockets too ? - fazersharp - 29-04-19 Think I will get myself a 600mm one which is £5 more than a 450mm one. I have bits of pipe but nothing very strong. Re: New Chain Time = Sprockets too ? - fazersharp - 29-04-19 (29-04-19, 08:26 PM)robbo link Wrote: The longer the breaker bar the better. As suggested if you're not in a tearing hurry ebay would be your best bet.Been looking at some ebay ones but for £10 incl del I am a bit dubious of the quality. £4 of the cost must be the post. Re: New Chain Time = Sprockets too ? - fazersharp - 29-04-19 (29-04-19, 05:02 PM)bandit link Wrote: there are a couple of ways to use the chain to remove the stubborn nut if you have never done it before.Would one of those be to remove the wheel and re insert the spindle and pin the chain to the spindle with a screwdriver. But what is the second chain way. Re: New Chain Time = Sprockets too ? - bandit - 29-04-19 (29-04-19, 09:07 PM)fazersharp link Wrote: [quote author=bandit link=topic=25205.msg297199#msg297199 date=1556553729]Would one of those be to remove the wheel and re insert the spindle and pin the chain to the spindle with a screwdriver. But what is the second chain way. [/quote] The first way is to get someone to apply the rear brake while you undo the nut easier with a helper but can be done on your own & the second way is to say put a piece of suitable timber say 2x4 from the right hand side between the wheel spokes resting on each side swing arm so the wheel locks on the wood which locks the chain so you can undo the nut. So when you torque up the new sprocket nut put the piece of wood under the swing arm locking the chain with the spoke of wheel. When you've done that bend the washer up but don't do it on opposite flats do it on two adjoining flats, like L shape. Hope that makes sense. I suggested Loctite 243 because it is suitable for dismantling with normal hand tools if required in the future. [img alt=Smile]http://foc-u.co.uk/Smileys/efocicon/smile.gif[/img] Re: New Chain Time = Sprockets too ? - fazersharp - 29-04-19 (29-04-19, 09:49 PM)bandit link Wrote: [quote author=fazersharp link=topic=25205.msg297228#msg297228 date=1556568462]Would one of those be to remove the wheel and re insert the spindle and pin the chain to the spindle with a screwdriver. But what is the second chain way. [/quote] The first way is to get someone to apply the rear brake while you undo the nut easier with a helper but can be done on your own & the second way is to say put a piece of suitable timber say 2x4 from the right hand side between the wheel spokes resting on each side swing arm so the wheel locks on the wood which locks the chain so you can undo the nut. So when you torque up the new sprocket nut put the piece of wood under the swing arm locking the chain with the spoke of wheel. When you've done that bend the washer up but don't do it on opposite flats do it on two adjoining flats, like L shape. Hope that makes sense. I suggested Loctite 243 because it is suitable for dismantling with normal hand tools if required in the future. [img alt=Smile]http://foc-u.co.uk/Smileys/efocicon/smile.gif[/img] [/quote]Thanks. Been looking at del boys garage vids Re: New Chain Time = Sprockets too ? - bandit - 29-04-19 Some peoples aren't to keen on them but I find them to be a good source of info to pass on here not fazer specific but gives a good idea to help others who may be new to bikes. Did you decide on which chain kit to go with, one with the silent rear sprocket?. Re: New Chain Time = Sprockets too ? - fazersharp - 29-04-19 Defiantly will be a gold D.I.D XV chain and the Ognibene silent front but still thinking about the silent rear, going to do some reading on it. I plan on using gear oil and a brush as a lube regime but just wondering if the rubber ring on the rear would just trap stuff. Or if because of it oil would pool a little and the result would be more fling - rather than sort of tracking across the sprocket face. This is a good view of the rear. I just like the shape holes in it and that it is silver, fancy it with stainless steel nuts but can not find out if it has a treatment of if its just going to be rusty steel down the linehttps://www.youtube.com/watch?v=Fk7OVEj8gqQ Re: New Chain Time = Sprockets too ? - darrsi - 30-04-19 (29-04-19, 10:56 PM)fazersharp link Wrote: Defiantly will be a gold D.I.D XV chain and the Ognibene silent front but still thinking about the silent rear, going to do some reading on it. I plan on using gear oil and a brush as a lube regime but just wondering if the rubber ring on the rear would just trap stuff. Or if because of it oil would pool a little and the result would be more fling - rather than sort of tracking across the sprocket face. Eh? You're overthinking this a bit too much. Paint the chain, wipe it with a rag, then if you really want to, put the bike in gear on the centre stand with a tiny bit of throttle and fling off any excess oil before you even go anywhere! Sorted. Dunno where you're even going with all this "silent" stuff, it's a motorbike not a boring electric car. What you need is some obscenely noisy slip on exhaust to piss your neighbour's off and cover up all unknown suspicious noises coming from wherever, it's a tried and tested method that's worked seamlessly for decades. :thumbup Re: New Chain Time = Sprockets too ? - Dynspud - 30-04-19 :agree A decent exhaust fixes loads of "issues" you think your bike might have. That and regular basic maintenance checks of the essentials. Your bike will always make some noises as it's a shed load of moving parts all whizzing around, moving up & down or rattling against each other and, on mine at least, they're 15+ years old in a lot of cases. ....and we know how much trouble 15 year olds can be Re: New Chain Time = Sprockets too ? - darrsi - 30-04-19 (30-04-19, 07:03 AM)Dynspud link Wrote: :agree His bike is not even a teenager any more.....it'll probably get married soon. :lol Re: New Chain Time = Sprockets too ? - fazersharp - 30-04-19 (30-04-19, 06:55 AM)darrsi link Wrote: Eh?That's what I do. I like the idea of the silent front as that is similar to the OEM. But the rear silent I don't think is necessary but it has nice fancy holes and a pretty silver colour and is cheaper (i think ) than paying for a fancy Renthal or something. Re: New Chain Time = Sprockets too ? - fazersharp - 30-04-19 Ordered this in the End https://www.ebay.co.uk/itm/Yamaha-FZS-600-S-Fazer-98-03-DID-JT-Quiet-Chain-And-Sprocket-Kit-P1/283334074132?hash=item41f806df14:g:eH0AAOSwm79ckjyC Re: New Chain Time = Sprockets too ? - darrsi - 30-04-19 Just a pre warning before you think something is wrong, when you fit a new D.I.D. chain it will make a buzzing sound for a while on the plastic chain guide. Re: New Chain Time = Sprockets too ? - fazersharp - 30-04-19 (30-04-19, 06:40 PM)darrsi link Wrote: Just a pre warning before you think something is wrong, when you fit a new D.I.D. chain it will make a buzzing sound for a while on the plastic chain guide.:thumbup Re: New Chain Time = Sprockets too ? - fazersharp - 30-04-19 @darrsi is any gear oil ok like this https://www.wilko.com/en-uk/comma-gear-oil-ep80w-90-gl4-mineral-1l/p/0077164?nst=0&gclid=EAIaIQobChMIm72N88j44QIV8QDTCh2tfgTMEAQYASABEgJBHPD_BwE&gclsrc=aw.ds Re: New Chain Time = Sprockets too ? - darrsi - 30-04-19 (30-04-19, 08:46 PM)fazersharp link Wrote: @darrsi is any gear oil ok like this https://www.wilko.com/en-uk/comma-gear-oil-ep80w-90-gl4-mineral-1l/p/0077164?nst=0&gclid=EAIaIQobChMIm72N88j44QIV8QDTCh2tfgTMEAQYASABEgJBHPD_BwE&gclsrc=aw.ds Yeah, truth is it still looks like oil and is still runny, so it's no different to look at, but the figures say it's heavier than normal so should stick around a little better. Always apply after a ride when the chain's still warm. |
