Rear Brake refurb - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Rear Brake refurb (/showthread.php?tid=81547) |
Re: Rear Brake refurb - fazersharp - 31-03-20 Great that helps a lot - it seems powerhouse are correct as they say 11mm - no mention of thickness (depth of recces ) though ------- still got your calipers out :lol Re: Rear Brake refurb - Gnasher - 31-03-20 (31-03-20, 04:46 PM)red98 link Wrote: haven`t got a seal to measure but i can measure the the caliper body which should be good enough,give me a minute... You need to allow for the crush effect, it's not much but must be allowed for say .05 - 1mm O/D. I've not got one to measure here but it should sit slightly proud no more than a mm. One of the cheaper ones will work no doubt, it's not like it moves but I've never used anything other than what I've stated. I would go for non split rebuild first, if you can't get the pistons out then go for a split, it's takes only an hour ish to rebuild the thing. Re: Rear Brake refurb - Gnasher - 31-03-20 (31-03-20, 04:59 PM)red98 link Wrote: bit unsteady with the camera.i need 3 right hands :lol Use the other end of the caliper yaw mate, it's designed for I/D measurements :thumbup Re: Rear Brake refurb - red98 - 31-03-20 i know that,senior moment... :rollin :rollin :rollin Re: Rear Brake refurb - Gnasher - 31-03-20 (31-03-20, 05:14 PM)red98 link Wrote: i know that,senior moment... :rollin :rollin :rollin We all get them :rollin :rollin
Re: Rear Brake refurb - fazersharp - 31-03-20 (31-03-20, 05:51 PM)Gnasher link Wrote: [quote author=red98 link=topic=26027.msg311535#msg311535 date=1585671260] We all get them :rollin :rollin [/quote]Its alright for you as you can get away with it just being a senior moment --- I'm just a twat :lol Re: Rear Brake refurb - Gnasher - 31-03-20 (31-03-20, 06:14 PM)fazersharp link Wrote: [quote author=Gnasher link=topic=26027.msg311537#msg311537 date=1585673488] We all get them :rollin :rollin [/quote]Its alright for you as you can get away with it just being a senior moment --- I'm just a twat :lol [/quote] :rollin :rollin :rollin :rollin :rollin :rollin
Re: Rear Brake refurb - red98 - 31-03-20 (31-03-20, 06:18 PM)Gnasher link Wrote: [quote author=fazersharp link=topic=26027.msg311539#msg311539 date=1585674850] We all get them :rollin :rollin [/quote]Its alright for you as you can get away with it just being a senior moment --- I'm just a twat :lol [/quote] :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin [/quote] Re: Rear Brake refurb - fazersharp - 31-03-20 I have ordered this one x1 https://www.wemoto.com/bikes/suzuki/gs_500_et/96/picture/seal_for_splitting_rear_caliper_-_per_seal Re: Rear Brake refurb - red98 - 31-03-20 only one :rolleyes Re: Rear Brake refurb - fazersharp - 31-03-20 (31-03-20, 10:03 PM)red98 link Wrote: only one :rolleyesoops sorry Re: Rear Brake refurb - red98 - 31-03-20 :lol ......i see wemoto are still trading, i ordered a couple of tyre valves this afternoon but don`t expect their usual speedy service... Re: Rear Brake refurb - Disorderlypunk - 31-03-20 ooh god - delboy got mentioned so lets just jump on in after i split, blasted and painted my rear calipers i definatly replaced mine because after a while they do harden/deform. the problem is using the correct material and i researched like mad into this because i didnt want to F up and use the wrong stuff like nitrile which is something delboy would prob use if he needed to replace (yeah i have problems with a lot delboys stuff) the easiest kind of o-ring to get is made of EPDM thankfully du-pont are chemists and let us into there world by giving a compatability list https://mscrm-dupont.secure.force.com/CRG_TlargiGuide https://mscrm-dupont.secure.force.com/CRG_TlargiGuide -its your brakes - its your lives - its a couple of quid i would rather not scrimp on Re: Rear Brake refurb - fazersharp - 31-03-20 (31-03-20, 11:07 PM)Disorderlypunk link Wrote: ooh god - delboy got mentioned so lets just jump on inNot a fan of his either, not sure what you are referring to about "o rings" brought a sealing washer for rejoining 2 halves from webmoto and pistons and seals from fowlers Re: Rear Brake refurb - Gnasher - 01-04-20 (31-03-20, 11:37 PM)fazersharp link Wrote: [quote author=Disorderlypunk link=topic=26027.msg311551#msg311551 date=1585692437]Not a fan of his either, not sure what you are referring to about "o rings" brought a sealing washer for rejoining 2 halves from webmoto and pistons and seals from fowlers [/quote] Your seal from Webmoto will be fine I'm sure. The use of Orings in place of flat seals isn't really the way to go, yes it will work, for how long I've know idea. An Oring is made to seal around a circumference or and edge, not flat surfaces and won't have the surface contact area of the flat seal. Flat surface area contact will be achieved by crushing the Oring which could cause deformity, which under pressure will leek. Yes it will work to a point, but I wouldn't recommend it. Re: Rear Brake refurb - fazersharp - 01-04-20 (01-04-20, 08:29 AM)Gnasher link Wrote: [quote author=fazersharp link=topic=26027.msg311552#msg311552 date=1585694276]Not a fan of his either, not sure what you are referring to about "o rings" brought a sealing washer for rejoining 2 halves from webmoto and pistons and seals from fowlers [/quote] Your seal from Webmoto will be fine I'm sure. The use of Orings in place of flat seals isn't really the way to go, yes it will work, for how long I've know idea. An Oring is made to seal around a circumference or and edge, not flat surfaces and won't have the surface contact area of the flat seal. Flat surface area contact will be achieved by crushing the Oring which could cause deformity, which under pressure will leek. Yes it will work to a point, but I wouldn't recommend it. [/quote]I have came across some croc whilst reading up. like, "soak the new seals in brake fluid to make them more supple and easier to fit" -- "don't get brake cleaner on them as it makes them brittle" Re: Rear Brake refurb - Gnasher - 01-04-20 (01-04-20, 11:19 AM)fazersharp link Wrote: I have came across some croc whilst reading up. like, "soak the new seals in brake fluid to make them more supple and easier to fit" -- "don't get brake cleaner on them as it makes them brittle" More useless internet opinions by people who know nothing or very little :rolleyes You can either just wipe the seals with a little fluid or brake grease, a little so the surface looks wet.
Re: Rear Brake refurb - fazersharp - 01-04-20 (01-04-20, 11:29 AM)Gnasher link Wrote: [quote author=fazersharp link=topic=26027.msg311564#msg311564 date=1585736387] More useless internet opinions by people who know nothing or very little :rolleyes You can either just wipe the seals with a little fluid or brake grease, a little so the surface looks wet. [/quote]A few years ago I fitted hel lines on the front and could not find any little sachets of grease cant remember how hard I looked on the internet but none of the local car factors or bike shops had sachets like they do of copper grease so I ended up buying a whole tub :eek Re: Rear Brake refurb - Disorderlypunk - 01-04-20 (01-04-20, 08:29 AM)Gnasher link Wrote: [quote author=fazersharp link=topic=26027.msg311552#msg311552 date=1585694276]Not a fan of his either, not sure what you are referring to about "o rings" brought a sealing washer for rejoining 2 halves from webmoto and pistons and seals from fowlers [/quote] Your seal from Webmoto will be fine I'm sure. The use of Orings in place of flat seals isn't really the way to go, yes it will work, for how long I've know idea. An Oring is made to seal around a circumference or and edge, not flat surfaces and won't have the surface contact area of the flat seal. Flat surface area contact will be achieved by crushing the Oring which could cause deformity, which under pressure will leek. Yes it will work to a point, but I wouldn't recommend it. [/quote] sorry i did say o ring but ment washer its cause i have a pack sat on my desk infront of me for when i get round to rebuilding my suspension (probably later todays lockdown project) Re: Rear Brake refurb - fazersharp - 01-04-20 (01-04-20, 01:04 PM)Disorderlypunk link Wrote: sorry i did say o ring but ment washer its cause i have a pack sat on my desk infront of me for when i get round to rebuilding my suspensionIm confused now - what have you got in front of you.
