Starting Issue - AGAIN - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Starting Issue - AGAIN (/showthread.php?tid=76859) |
Re: Starting Issue - AGAIN - fazersharp - 16-12-16 (16-12-16, 10:42 AM)darrsi link Wrote: I've got my bike tanked up with around 400ml of 99% proof IsopropylDarrsi's Fazer Re: Starting Issue - AGAIN - darrsi - 16-12-16 It's more like this at the moment :lol Re: Starting Issue - AGAIN - darrsi - 16-12-16 Came out of work this evening, pressed the button, bike on sidestand......started immediately! This is all now aiming at water settling in the carbs when the bike is leant over all day/night. I reckon the 99% alcohol has started doing its job in the tank, clearing the water by binding and burning it off. I'll keep trying it now on the sidestand and see what happens. If this is the reason then i presume the only way for water to enter the tank is via the tank cap? So, what is the preferred and most effective way of stopping water from penetrating the tank in future? Re: Starting Issue - AGAIN - darrsi - 17-12-16 Hmmm, just been having a read, and someone mentioned having water in their fuel pump! I s'pose as any water/moisture lies low it could remain dormant and slowly build up over time causing starting problems. Even more good reason to use the alcohol trick to flush it from the system.
Re: Starting Issue - AGAIN - ogri48 - 17-12-16 I had a old z1000 a few years back that suffered these intermittent problems, and the fix given to me by a old zed head was brilliantly simple. As the fellers have said the low tension side of things doesn't take a lot to drastically alter the high tension side. If your getting say 11 volts at the coils instead of 12, multiplying many many times over and being converted to high tension that one volt loss becomes a helluva lot more. If you check the voltage to the coils ( low tension) you may well find there's a drop, caused by old wiring and old joints leaking off voltage which is what my problem was. Fix was to run a live feed to the coils direct from the battery via a relay, useing the original coil live feed as the switch wire. Sounds simple because it is, but it worked, plugs ran a lot cleaner too. Just another thing to look into mate :-) also, that bike ran dreadfully on iridium plugs, as have a few I've owned, no idea why, some bikes just don't like the buggers..:-) Re: Starting Issue - AGAIN - darrsi - 17-12-16 (17-12-16, 11:06 AM)ogri48 link Wrote: I had a old z1000 a few years back that suffered these intermittent problems, and the fix given to me by a old zed head was brilliantly simple. As the fellers have said the low tension side of things doesn't take a lot to drastically alter the high tension side. If your getting say 11 volts at the coils instead of 12, multiplying many many times over and being converted to high tension that one volt loss becomes a helluva lot more. If you check the voltage to the coils ( low tension) you may well find there's a drop, caused by old wiring and old joints leaking off voltage which is what my problem was. Fix was to run a live feed to the coils direct from the battery via a relay, useing the original coil live feed as the switch wire. Sounds simple because it is, but it worked, plugs ran a lot cleaner too. Just another thing to look into mate :-) also, that bike ran dreadfully on iridium plugs, as have a few I've owned, no idea why, some bikes just don't like the buggers..:-) Thanks for the tip. The bike runs spot on once started,and i couldn't be happier with it. I've changed a lot of parts recently just to rule them out, which weren't expensive, and bearing in mind the bikes age i thought it wouldn't hurt anyway. For now it does seem like the problem has been found, but i'll put some more booze in the tank next time i fill it up to make sure it clears any leftover moisture out. And anyway, everyone deserves a drink at Xmas, even my bike. :b I never really needed to change my plugs, as because they were Iridium there is probably years left on them as i don't do high mileage, but i did notice i had CR9EIX plugs in before but replaced them with CR8EIX ones, but i doubt very much that it makes any difference at all to the running of the bike, as they both cover our climate quite comfortably. I kept them so can always change them back if i want, but i really don't feel the need to. Re: Starting Issue - AGAIN - tommyardin - 17-12-16 (16-12-16, 11:52 PM)darrsi link Wrote: Came out of work this evening, pressed the button, bike on sidestand......started immediately! Or a dirty supply at the point of re-fueling, try a different gas station. Re: Starting Issue - AGAIN - darrsi - 17-12-16 (17-12-16, 03:36 PM)tommyardin link Wrote: [quote author=darrsi link=topic=21305.msg247840#msg247840 date=1481928748] Or a dirty supply at the point of re-fueling, try a different gas station. [/quote] I mainly use the same garage simply because it's the only one that does 97 RON fuel that i know of. Not keen on the 95, and 99 is okay but is a waste of money for a commuter bike. |
