stuttering fzs 600 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: stuttering fzs 600 (/showthread.php?tid=57718) |
Re: stuttering fzs 600 - red98 - 16-09-12 (15-09-12, 11:13 PM)nickodemon link Wrote: [quote author=red98 link=topic=2066.msg39244#msg39244 date=1347737638] if you take the tank of and remove the tap and fuel guage sender you can flush it out quite easily se what comes out has the bike been sat around for a while [/quote] I'm going to take tank off and drain. I've just bought the bike, so i don't really know how long its been lying. [/quote] a good flush out then .........might be good to drain the carbs aswell
Re: stuttering fzs 600 - nickodemon - 16-09-12 Going to do that this morning. Let you know how i get on. Re: stuttering fzs 600 - nickodemon - 16-09-12 Flushed the tank out. The fuel had loads of rusted flakes of metal in it, so i completely drained the tank and carb float bowls. Filled the tank with fresh fuel and went for a spin. To begin with it was pretty spluttery, but i think that was down to the fact carbs were drained and new fuel filter fitted. After about a 1/4 mile the bike ran sweet. Went out again this evening and same again revved out perfectly. I will hold back jumping for joy until i have used it for a few days, but it seems to be running much better
Re: stuttering fzs 600 - red98 - 16-09-12 (16-09-12, 07:30 PM)nickodemon link Wrote: Flushed the tank out. The fuel had loads of rusted flakes of metal in it, so i completely drained the tank and carb float bowls. Filled the tank with fresh fuel and went for a spin. To begin with it was pretty spluttery, but i think that was down to the fact carbs were drained and new fuel filter fitted. After about a 1/4 mile the bike ran sweet. Went out again this evening and same again revved out perfectly. I will hold back jumping for joy until i have used it for a few days, but it seems to be running much better fingers crossed for you matey .....give us the good news at the end of the week [size=78%] [/size]
Re: stuttering fzs 600 - CRH - 17-09-12 Cmon red?...put us out of us misery?....is it sorted? :rolleyes Re: stuttering fzs 600 - red98 - 17-09-12 mmmmmmmmmmm not good :\ ...................at last i had some spare time in the garage i used the colour tune on three of the four cylinders (cant seam to reach cyl 3 easily) and set a little bit rich, iam more or less on 5 turns :\ so start it up and i have a big stutter at 5/6000 in neutral on the center stand :\ just like hitting a rev limiter and wont pull through :'( so i put the mixture screws back to 4 turns (its been running that for the last 30,000 miles) and no change :\ ive made things worse and i dont know why :'( :'( :'( :'( :'( :'( :'( :'( Re: stuttering fzs 600 - CRH - 17-09-12 right!!....try weakening it even further to see if it gets worse?...at least then you proving its fuel prob!! set them to 3 and see what happens>> :rolleyes ..... Re: stuttering fzs 600 - red98 - 17-09-12 (17-09-12, 07:35 PM)CRH link Wrote: right!!....try weakening it even further to see if it gets worse?...at least then you proving its fuel prob!! set them to 3 and see what happens>> :rolleyes ..... [size=78%]hi crh.....just closed the garage door and walked away [/size] :\ .........your right thats the next logical step not tonight though ,had enough,going to have a nice long soak in the bath and parhaps a beer after
Re: stuttering fzs 600 - CRH - 17-09-12 dont blame you!!....dont give up though?....you come too far?? ..you will get it right?.
Re: stuttering fzs 600 - red98 - 17-09-12 (17-09-12, 07:45 PM)CRH link Wrote: dont blame you!!....dont give up though?....you come too far?? no not going to give up,just need a break [size=78%]........i work 7 days a week during the summer and always feel a bit down at this time of year, day off on saturday so going to london to see a show followed by dinner and a few drinks [/size] just what the doctor ordered [size=78%]thanks for your support CRH when the old girl is purrrrrrrrrring again that will be one big drink iou [/size]
Re: stuttering fzs 600 - Fazerider - 17-09-12 I balanced the carbs on mine this afternoon. While hooking up the vacuum gauges to the take-off points on the inlet manifolds I found the little rubber caps had perished quite badly: ![]() I don't think they'd quite gone all the way through, the one I tried sucking on was OK anyway... I didn't test the others 'cos I didn't like the taste. As a precaution I smeared some silicone sealant into the cracks. With all the dismantling and checking you've been doing I don't suppose that sort of thing would have missed your notice, but thought I'd mention it anyway as a possible cause of a weak mixture. Re: stuttering fzs 600 - ade the blade - 17-09-12 (17-09-12, 07:35 PM)CRH link Wrote: right!!....try weakening it even further to see if it gets worse?...at least then you proving its fuel prob!! set them to 3 and see what happens>> :rolleyes .....did somebody mention the word fuel perchance?.....and we know what that passes through don`t we?...no Clive, not just fuel lines !! :lol :lol :lol Re: stuttering fzs 600 - red98 - 17-09-12 (17-09-12, 08:13 PM)Fazerider link Wrote: I balanced the carbs on mine this afternoon. While hooking up the vacuum gauges to the take-off points on the inlet manifolds I found the little rubber caps had perished quite badly: well spotted fazerider [size=78%]......a split like that would indeed affect the mixture big time,mine are ok,but will double check to make sure ,just need to backtrack a bit now and see what i find[/size] thanks for your input matey,did you notice the difference now your carbs are all pulling together
Re: stuttering fzs 600 - red98 - 17-09-12 (17-09-12, 08:36 PM)ade the blade link Wrote: [quote author=CRH link=topic=2066.msg39422#msg39422 date=1347906959]did somebody mention the word fuel perchance?.....and we know what that passes through don`t we?...no Clive, not just fuel lines !! :lol :lol :lol [/quote] hi ade ,still hoovering then ..........i think the greatest moment in you life is just around the corner [size=78%]..........CRH its over to you !!!![/size]
Re: stuttering fzs 600 - ade the blade - 17-09-12 (17-09-12, 08:43 PM)red98 link Wrote: [quote author=ade the blade link=topic=2066.msg39431#msg39431 date=1347910570]did somebody mention the word fuel perchance?.....and we know what that passes through don`t we?...no Clive, not just fuel lines !! :lol :lol :lol [/quote] hi ade ,still hoovering then ..........i think the greatest moment in you life is just around the corner [size=78%]..........CRH its over to you !!!![/size][/quote] hoovering? :rolleyes ......Clive is weakening. the force is strong though :rollin :rollin :rollin seriously matey, 5 turns is a big no no. did you pull the plugs out of curiosity to see if they were jet black with chimney soot :lol :lol :lol Re: stuttering fzs 600 - CRH - 17-09-12 ime still thinking i am?...yes the force is strong!! ...got me waterproofs, sterodent, tissues ALL on standby ade!! :b ....just incase? :'( .....red?....dont forget the carbs i got stripped?...you need owt boyfriend they yours!!
Re: stuttering fzs 600 - red98 - 17-09-12 (17-09-12, 08:51 PM)ade the blade link Wrote: [quote author=red98 link=topic=2066.msg39433#msg39433 date=1347910999]did somebody mention the word fuel perchance?.....and we know what that passes through don`t we?...no Clive, not just fuel lines !! :lol :lol :lol [/quote] hi ade ,still hoovering then ..........i think the greatest moment in you life is just around the corner [size=78%]..........CRH its over to you !!!![/size][/quote] hoovering? :rolleyes ......Clive is weakening. the force is strong though :rollin :rollin :rollin seriously matey, 5 turns is a big no no. did you pull the plugs out of curiosity to see if they were jet black with chimney soot :lol :lol :lol [/quote] the plugs did have a white tinge before i started but not checked since running on 5 turns,will look tomorrow clives gone quite.........no doubt busy flossing and brushing :rolleyes Re: stuttering fzs 600 - CRH - 17-09-12 already answered mate?...not gone quiet?...just looking on route planner! best way t ades? Re: stuttering fzs 600 - ade the blade - 17-09-12 (17-09-12, 09:20 PM)CRH link Wrote: already answered mate?...not gone quiet?...just looking on route planner! best way t ades?just head due south, prison bitch! :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin and dont forget the elmlea !! Re: stuttering fzs 600 - CRH - 17-09-12 double whipp uhf spray already in top box matey?.... :b ....not looking good f me is it.. |
