Bigger front sprocket - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Bigger front sprocket (/showthread.php?tid=79456) |
Re: Bigger front sprocket - fazersharp - 07-04-18 (07-04-18, 12:00 AM)Disorderlypunk link Wrote: [quote author=Millietant link=topic=23930.msg277936#msg277936 date=1523051463] yep the correct way is to do that that, i think the idea here is a quick switch (15 mins to switch and adjust for front sprocket) im not doing a full maths spreadsheet on this (i said that last time lol) i have a feeling not everyone here has a paddock stand to do full switches so its just easier and also its £5 for a front sprocket and much more for a rear so quick switch is worthy of a trial run -- if we dont test run it we dont know ---- [/quote] Whilst you are on the maths there is also another factor in that certain combo's of teath will create a situation where the same link will hit the same tooth over and over again. It was discussed on here a while back - have a search. Re: Bigger front sprocket - Millietant - 07-04-18 (07-04-18, 10:23 AM)fazersharp link Wrote: [quote author=Disorderlypunk link=topic=23930.msg277943#msg277943 date=1523055657] yep the correct way is to do that that, i think the idea here is a quick switch (15 mins to switch and adjust for front sprocket) im not doing a full maths spreadsheet on this (i said that last time lol) i have a feeling not everyone here has a paddock stand to do full switches so its just easier and also its £5 for a front sprocket and much more for a rear so quick switch is worthy of a trial run -- if we dont test run it we dont know ---- [/quote] Whilst you are on the maths there is also another factor in that certain combo's of teath will create a situation where the same link will hit the same tooth over and over again. It was discussed on here a while back - have a search. [/quote] I can see the logic, but in over 40 years of making this change on all of my in-line 4's, I've never had a sprocket or chain wear/fail early. In fact, I've generally changed my chains and sprockets due to my "impression" of mileage & timescale, rather than anything actually being worn-out (prevention being the best way to avoid problems). Having said that, my FJ 1200's have both run well over 20k mikes on each chain and sprocket set, as did my Aprilia RSV. I changed the Fazer 1000 originals at 17k miles just because I wanted to alter the gearing, not because they were worn out. Maybe I'm just lucky ! Re: Bigger front sprocket - fazersharp - 07-04-18 (07-04-18, 02:21 PM)Millietant link Wrote: [quote author=fazersharp link=topic=23930.msg277959#msg277959 date=1523092999] yep the correct way is to do that that, i think the idea here is a quick switch (15 mins to switch and adjust for front sprocket) im not doing a full maths spreadsheet on this (i said that last time lol) i have a feeling not everyone here has a paddock stand to do full switches so its just easier and also its £5 for a front sprocket and much more for a rear so quick switch is worthy of a trial run -- if we dont test run it we dont know ---- [/quote] Whilst you are on the maths there is also another factor in that certain combo's of teath will create a situation where the same link will hit the same tooth over and over again. It was discussed on here a while back - have a search. [/quote] I can see the logic, but in over 40 years of making this change on all of my in-line 4's, I've never had a sprocket or chain wear/fail early. In fact, I've generally changed my chains and sprockets due to my "impression" of mileage & timescale, rather than anything actually being worn-out (prevention being the best way to avoid problems). Having said that, my FJ 1200's have both run well over 20k mikes on each chain and sprocket set, as did my Aprilia RSV. I changed the Fazer 1000 originals at 17k miles just because I wanted to alter the gearing, not because they were worn out. Maybe I'm just lucky ! [/quote] As I recall your combo was actually the optimum sweet spot ratio to avoid any same link -tooth wear Re: Bigger front sprocket - unfazed - 07-04-18 Hope that fits with the chain on, in the space between the sprocket and clutch pushrod :eek a 16t runs it close |
