Doing a bit of that 'Ivanising' in April - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Doing a bit of that 'Ivanising' in April (/showthread.php?tid=74817) |
Re: Doing a bit of that 'Ivanising' in April - Falcon 269 - 05-05-16 I adjusted the throttle slack when I refitted the carbs, so that shouldn't be a factor. Drop me and e-mail with more of the symptoms and we'll sort it out. Do you have heated grips? Re: Doing a bit of that 'Ivanising' in April - kitcrazy - 05-05-16 Throttle is returning fine apart from when bikes on full left lock. Re: Doing a bit of that 'Ivanising' in April - Falcon 269 - 06-05-16 In which case try putting a little extra slack in the cable with the adjuster at the throttle tube end. Are they standard bars or wider aftermarket ones? Re: Doing a bit of that 'Ivanising' in April - kitcrazy - 06-05-16 Will do cheers Mike. Re: Doing a bit of that 'Ivanising' in April - kitcrazy - 06-05-16 Standard bars mate Re: Doing a bit of that 'Ivanising' in April - ting - 07-05-16 hi mike is the full monty compatible if you have the 4 degree ignition advancer fitted ? Re: Doing a bit of that 'Ivanising' in April - mickvp - 07-05-16 (07-05-16, 07:08 PM)ting link Wrote: hi mike is the full monty compatible if you have the 4 degree ignition advancer fitted ? It is indeed. I've got a full monty from Mike and an advanced fitted
Re: Doing a bit of that 'Ivanising' in April - PieEater - 08-05-16 (07-05-16, 08:59 PM)mickvp link Wrote: [quote author=ting link=topic=19253.msg231524#msg231524 date=1462644533] It is indeed. I've got a full monty from Mike and an advanced fitted ![]() [/quote] Me too, I find the gains at the bottom of the rev range are worth any slight loss at the top end. |
