Leaking Fazer FZS600 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Leaking Fazer FZS600 (/showthread.php?tid=74486) |
Re: Leaking Fazer FZS600 - unfazed - 09-01-16 Top pipe of the coolant expansion tank is an over flow/breather and should route down the side of the engine behind the clutch cover. The bracket attached to the air filter housing under the tank should have the pipe attached to under side of it routed down the same way behind the clutch cover. That pipe is to drain water or fuel over fill from the tank filler area to the ground Re: Leaking Fazer FZS600 - aquilaalba - 11-01-16 I will have to re-create this as on mine there should be a little 'funnel' which is missing - apparently - yet, I'll get two pipes connected to the tank outlets and run them by the clutch cover as it should be. Taking quite a bit to get back to bog standard... Re: Leaking Fazer FZS600 - Hoppy - 23-01-16 best not to taste or put near your mouth or food as toxic |
