HID Headlights - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: HID Headlights (/showthread.php?tid=73336) |
Re: HID Headlights - b1k3rdude - 10-08-15 (10-08-15, 03:10 PM)PaulSmith link Wrote:
(10-08-15, 03:48 PM)PaulSmith link Wrote: Some interesting information the use of LEDs in a reflector designed for point source here. (If you are easily bored, skip the first 22 minutes)Nice find -
(10-08-15, 08:13 PM)AyJay link Wrote: Thanks for the info! I'm still kind of baffled as to why so many bikes with these are dazzleships though.Its because -
Re: HID Headlights - PaulSmith - 11-08-15 Thank you. That is the first piece of evidence you have posted. A You-tube video. That it contradicts some of your points is a little embarrassing but it is great to see that you are finally using evidence. 1. measure the center point of the arc Let me try again. You do NOT need to measure the centre point of the arc. Look again at the specifications that I posted. There is NO measurement to where the centre of the light is. There is a measurement to the position between the low beam and the high beam where the light isn't. The position you measure is the gap between the low and the high beams. The place where there is no light coming from between the high and the low filaments is the place you need to measure. It needs to be certain distance from the baseline. A H4 bulb can give off light from two different positions. The high beam position and the low beam position. The position of the low beam must stop before the high beam can start so the reflector can do its job. You claimed that all HID bulbs where made with the light source in the wrong position. The specification I posted shows how to measure a bulb. The picture I posted shows a bulb being measured. The position in the picture matches the position in the specification proving that the light source is in the correct place, proving that your claim is wrong. That is the point. 2. Try several millimetres Try some evidence. Even the video you posted shows that the lateral movement, if it could be measured, would be less then a 10th of a milimeter. That is not enough to affect alignment. 3. Baffle hole that its too small Too small for what exactly? 4. The reflector is not "seeing" all of the arc Again, some evidence would help. Or, at the risk of repeating myself, so? 5. ...its pulling more on hi-beam than a Halogen bulb would be. Now you are just making shit up. Why don't you measure the resistance of the solinoid on one of the many HID bulbs you have lying about and apply ohms law to determine its current draw. You can even impose worst case weak battery/damaged alternator scenario and calculate draw at 10 volts instead of 12. 6. ...bulb dosent stay perfectly central Now I am repeating myself. So? Or if you prefer, I refer the honourable gentleman to the reply provided to question 2. 7. ...That's far far less than the advertised 3000hrs True. That said, they are fitted to a motorbike and not sitting on a test bench. I never got the advertised life out of a traditional bulb either but it is not like a failure is going to leave you stranded since everything is doubled up. That said. I do carry a traditional H4 bulb under the seat when I am going on longer trips. Now to LEDs. CREE are a manufacturer, not a bulb type. You would get almost exactly the same results with LED replacements for H4 bulbs from any other manufacturer. The problem is not who makes them, or what type emitter is used, or the position of the LED elements, (which by the way are as 'right' as it can be given the nature of LEDs), it is much simpler than that. As I have mentioned more than once, LED emitters are not point sources. LEDs are surface mounted with the light being emitted perpendicular to the surface. Yes there is a lot of spread, but none of the light can go through the surface so full surround reflectors (the type you get with H4 bulbs etc.) are not a lot of use. The result is clear from the video. The light source emits as much or more light (in Lumens) as traditional H4 bulbs, but the direction it is shining in means the reflectors can not point much of it down the road. And finally - The position of the arc bulb within the main glass envelope is almost always incorrect... No it fucking isn't as I have proven. The light output from a HID is just to powerful, Correct. Pity the rest of the sentence is bullshit. You used this argument the last tim eyou tried to knock HIDs and I proved, using MOT documents, that the test is for the pattern which is correct or it isn't. The intensity is neither measured not important. there is enough freeplay to allow them to wobble and jiggle I refer the honourable gentleman to the reply provided to question 2. arc itself which isn't actually fixed I refer the honourable gentleman to the reply provided to question 2. Re: HID Headlights - b1k3rdude - 11-08-15 @PS, I really don't know your issue is but, you have gone out of your way to pick holes or just be plain argumentative with every point I have made. On several occasions you have demonstrated that your grasp of the technology is highly subjective, so to that end I have lost any and all interest trying to explain the facts, that are obvious to everyone else but you. Re: HID Headlights - 7omly - 11-08-15 I'm thinking of fitting HIDs and asked my mate (MOT Inspector) about legality. His reply was the only specific criteria for motorcycles is they musn't dazzle other road users. So when I get them fitted i will take them down to his beam alignment machine and have them set up properly. I figure if HIDs are 300% brighter than halogens then i can afford to set them a little lower than normal to avoid dazzle. With regards to bulb life, i once paid over £27 for a pair of Osram H7 Nightbreakers which although fitted to a car lasted less than 5 months. Anything fitted to a motorcycle gets an hard life due to vibration, extreme temperatures and exposure to the elements. You can buy two HID lamps off ebay for under a tenner, if I had to pay £20 a year to be able to actually see at night I'd be happy to. Re: HID Headlights - PaulSmith - 12-08-15 (11-08-15, 01:28 PM)b1k3rdude link Wrote: [size=1em]@PS, I really don't know your issue is but, you have gone out of your way to pick holes or just be plain argumentative with every point I have made. On several occasions you have demonstrated that your grasp of the technology is highly subjective, so to that end I have lost any and all interest trying to explain the facts, that are obvious to everyone else but you.[/size]Remember that we talked about this before. Facts and opinions are not the same thing. You are entitled to your opinions but facts require the support of evidence. https://www.youtube.com/watch?v=dS12p0Zqlt0 I have picked holes in every argument you made that had holes in it. The difference is that I did not rely on my expertise or experience, I provided evidence. The facts that are obvious to everyone are: HIDs are three times brighter then traditional bulbs, HIDs use a third less power then traditional bulbs and (currently) HIDs are cheaper then traditional bulbs, but if you are the type of person who does not know or care about how to align their lights correctly, then they are probably not for you. The one new fact that I have learnt is that HIDs have 'haters'. People who believe that HIDs are abominations that must be stamped out. It appears to be a religious belief as the facts, evidence and the truth does not seem to matter to these people. I have been lucky enough to have never met one before, but now I am a little wiser. Re: HID Headlights - b1k3rdude - 12-08-15 (11-08-15, 11:06 PM)7omly link Wrote: I'm thinking of fitting HIDs and asked my mate (MOT Inspector) about legality. His reply was the only specific criteria for motorcycles is they musn't dazzle other road users.While your at it get the 4300k kits because 1. as you go up the temp range thew lumens drops (so 4300K bulbs put out the most light), 2. 4300 is the closest to white and its a legal req. that front facing light be white. Re: HID Headlights - Just Fazered - 15-08-15 Jeez, I started reading some of this rambling debacle regarding HID Vs H4 Vs LED lights, then realised I almost nodded....off! It's true, the lights on but nobodies in :lol Re: HID Headlights - tnfazer - 30-08-15 As much as I like a good argument, I am thinking about skipping HIDs and going straight to LED replacement bulbs based on some positive press reviews I've read. Admittedly without much expertise the hi/lo switch seems simpler with LEDs, and that's anyway the way the world is going. I'm retrofitting my home lightning gradually with 4000K LEDs and wonder why other people bother to sit in the dark :rolleyes I don'r ride that often in the dark, but when I do I want to light up the woods to minimize the chances of barreling into a moose or a deer (and heck, I just got warned yesterday about wild boars in the area I'm going to next weekend). Anyone tried or thought about these? http://www.cyclopsadventuresports.com/3800-Lumen-H4-LED-Headlight-bulb-_p_83.html Re: HID Headlights - PaulSmith - 31-08-15 The issue with LEDs is that they are surface mount light sources and not point sources. That means the light shines away from the surface and not evenly in all directions. Have a look at the picture in the link you provided and you will see what I mean, it shows the emitters side on. No way are you going to get the same amount of light as head on. You might get lucky and pick a bulb where the direction of the light suits the reflector you have really well, but then again, you might not. Your lights do two jobs; they let you see and they let you be seen. LEDs are excellent for being seen because the provide an intense light very close to daylight, but because it is very hard to focus it without a properly designed reflector, they are not so could when it comes to seeing what is there. If you did mainly city driving, they might be fine, but I would not recommend them for avoiding the wildlife. Re: HID Headlights - bludclot - 31-08-15 fwiw i changed my side light bulbs for LED in order to be seen better. i changed my dipped/main bulbs for LED and they were terrible (main beam didn't even work!), so opted for Osram Nightbreakers. i find these to be a bit better than standard bulbs, probably worth about the £12 or so from ebay. Re: HID Headlights - PaulSmith - 31-08-15 (31-08-15, 02:57 PM)bludclot link Wrote: fwiw i changed my side light bulbs for LED in order to be seen better. i changed my dipped/main bulbs for LED and they were terrible (main beam didn't even work!), so opted for Osram Nightbreakers. i find these to be a bit better than standard bulbs, probably worth about the £12 or so from ebay.If you are not in a hurry, the same money will get you a HID kit in ebay from Chine (one month delivery), give it a try and if you don't like it you can chuck it. |
