sprocket nut - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: sprocket nut (/showthread.php?tid=73199) |
Re: sprocket nut - anutz - 16-07-15 just be careful the transmission is not in gear so you don't rive the hell out of it, make sure someone has the back brake on and use the chain to hold/oppose the thing.. Re: sprocket nut - paulchucky - 16-07-15 best thing is to be sure your on the safe side get it sorted ! after all a man has to be sure about his NUTS :lol :lol Re: sprocket nut - sinto607276 - 16-07-15 (16-07-15, 09:27 PM)paulchucky link Wrote: after all a man has to be sure about his NUTS :lol :lol :uhuh remember what you've been told about checking your nuts regularly too :rolleyes Re: sprocket nut - anutz - 16-07-15 if anything goes wrong i always reach for my nutz......look at my username "anutz"...... Re: sprocket nut - sinto607276 - 16-07-15 (16-07-15, 09:52 PM)anutz link Wrote: if anything goes wrong i always reach for my nutz......look at my username "anutz"......There was me thinking you couldn't spell :b Re: sprocket nut - Freck - 18-07-15 Hi fazersharp, here's my experience after your request for more info from 98 owners. I've not long had my 98 600 and as yet haven't ridden it as I'm in the process of giving her a tidy up. After reading about the possible issue relating to the original 9mm nut, and finding that the chain on sprockets would benefit from renewing, I opened up the sprocket cover and found the mess shown in the pics below. It looks like the front sprocket has never been touched (bike has done about 42k :eek ) and still has the original 9mm nut. Thankfully, it was still tight, the retaining washer folded over on 2 sides. Flattening off the washer I undid the nut which was a little stiff but not too bad, and the threads were all intact. I'd say that it would never have come loose on its own. I will, however replace it with a new 12mm nut and retaining washer and a little loctite to be on the safe side. Obviously, I'll be cleaning up the gunk before fitting the new c&s kit Steve Re: sprocket nut - fazersharp - 18-07-15 Thanks for that Freck I dont meant to hijack the OP but as he has a 98 it is sort of relevant. Be good to also post up your "after" cleaning photos Re: sprocket nut - Freck - 18-07-15 (18-07-15, 08:03 PM)fazersharp link Wrote: Be good to also post up your "after" cleaning photosYep, no problem. It might be a while before I get to post them though as I'm currently 4000 miles away from home with work Steve Re: sprocket nut - fazersharp - 18-07-15 Thats a heck of a commute Re: sprocket nut - snakeyprince83 - 18-07-15 changed it today, it wasnt loose enough that i could turn it with my fingers but it didnt take much with the wrench at all, came right off, i tightened it to 80. Was much easier than i thought. Next is to save some pennies for the retrofit labs headlight conversion kit so i can see where i'm going in the dark, cheers all! Re: sprocket nut - darrsi - 19-07-15 (16-07-15, 09:27 PM)paulchucky link Wrote: best thing is to be sure your on the safe side :lol |
