intermittant misfire - Printable Version
+--- Thread: intermittant misfire (/showthread.php?tid=71569)
Pages: 1 2 3
Re: intermittant misfire - wildchild74 - 04-03-15
Right folks next instalment of the misfire saga.... drained 2 carbs n knackered carb 4 drain screw so couldnt drain it so went inside just to get away from it b4 i lost it...then thought f!@#k it and put in the stp n petrol and took it out gave it a good thrash now the misfire seems to be going but the revs seem to stick on at about 1500rpm resulting in no engine braking... will this go the more i use it plus will the treatment break down the blockage while its sitting in the carbs thanks
Gaz
Re: intermittant misfire - stevie-g1968 - 05-03-15
have you adjusted the idle down, or did you turn it up to compensate for the poor idle issue you have had?
try turning it down to 1200 and see how it runs... the cleaner may take a few runs to fully shift any crap.
my mechanic told me to use injector cleaner in mine after a lay up, so ive done this the other day as my bike had no been out since last October and it runs fine.
Re: intermittant misfire - wildchild74 - 05-03-15
(05-03-15, 07:13 PM)stevie-g1968 link Wrote: have you adjusted the idle down, or did you turn it up to compensate for the poor idle issue you have had?
Hi m8 unless ive knocked it while f-ing about round that area no not as im aware of n good news is ive drained carbs 3 n 4, primed them n letting them soak now overnite n will fire it up tomorrow n take out for a blast hopefully cheers m8
Gaz
Re: intermittant misfire - wildchild74 - 08-03-15
Hi folks this is getting boring now i know but the saga continues :o... broke my neck friday to finish early so i could get the bike out for a long blast the intention was wolverhampton, bridgnorth,telford n back to wolverhampton but only managed bridgnorth and back but what i did notice was the misfire is apparant up to 3.5k-4k rpm then it howls lovely right upto 10k rpm then loads of popping on the way back down the revs sooo took it to mechanic yesterday n cyl 1 was running 70° lower than the rest n he thinks deffo carb prob so ive brought a set off rmt on here n hopefully swap them over in the week n keep you posted
Gaz
Re: intermittant misfire - darrsi - 08-03-15
(08-03-15, 12:45 PM)wildchild74 link Wrote: Hi folks this is getting boring now i know but the saga continues :o ... broke my neck friday to finish early so i could get the bike out for a long blast the intention was wolverhampton, bridgnorth,telford n back to wolverhampton but only managed bridgnorth and back but what i did notice was the misfire is apparant up to 3.5k-4k rpm then it howls lovely right upto 10k rpm then loads of popping on the way back down the revs sooo took it to mechanic yesterday n cyl 1 was running 70° lower than the rest n he thinks deffo carb prob so ive brought a set off rmt on here n hopefully swap them over in the week n keep you posted
Gaz
You're only on Page 2, we're more patient than that, try reading this one.  :lol
http://foc-u.co.uk/index.php/topic,2066.0.html
(08-03-15, 01:40 PM)darrsi link Wrote: [quote author=wildchild74 link=topic=15991.msg186269#msg186269 date=1425815132]
Gaz
Lol m8 trust me this wont reach 42 pages it will be off to bike heaven way b4 then lmfao
Gaz
Re: intermittant misfire - wildchild74 - 09-03-15
Guys ive taken the carbs off awaiting a set off rmt but while ive got access to it i want to check the cam chain tensioner while i can does anyone the procedure to remove,inspect and lubricate and put back without knackering the chain thanks
Gaz
Re: intermittant misfire - unfazed - 10-03-15
If there were no rattles when the bike was running leave it alone  Smile
Re: intermittant misfire - wildchild74 - 10-03-15
(10-03-15, 12:33 AM)unfazed link Wrote: If there were no rattles when the bike was running leave it alone  Smile
Hi m8 it does rattle a bit but not enough to warrant messing with something that could poss knacker the engine
Gaz
Re: intermittant misfire - unfazed - 11-03-15
Highly unlikely the tensioner is a problem, mostly like a wearing chain or valve clearance to big.
Cam Chains like drive chains do not wear uniformly they have loose and tight spots. This causes a light rattle especially on startup and the only know cure is to replace the chain.
What mileage is on the engine?
The tensioner is easy enough to remove if you still want to.
Remove the alternator/Generator cover.
Rotate the the crank anticlockwise until the T mark lines up with where the top and bottom crankcases meet.
Some will say you do not need to do this, but it is the best position to have the chain in when removing the tensioner.
Do not rotate the crank when the tensioner has been removed
Remove the 10mm bolt at the end of the tensioner. There is a ball bearing within the bolt, don't lose it.
Don't lose the copper washer on the bolt
Remove the springs (one is inside the other)
Loosen the two allen bolts and carfully remove the tensioner.  There is another ball bearing inside in the tensioner don't lose that either.
If your lucky the gasket will remain intact, if not replace it. It is probably best to replace it anyway.
Lift the ratchet and push back the tensioner.
Oil it up and with the ratchet held off the tensioner push the tensioner in and out of the housing a few times.
Replacment is more or less the reverse order of the removal.
Tensioner pushed back into the housing
Gasket
Tensioner body
Tighten the Allen bolts to 10Nm
Ball bearing
Springs
Push them in to the tensioner (You will hear the ratchet clicking over the ratchet teeth)
Put Ball Bearing into cap Bolt and copper washer on the bolt.
Put it on the tensioner and tighten it to 20Nm
Now rotate the engine slowly two full turns. You will probably here the ratchet taking up a little more slack.
You might as well check the valve clearances as you have the Alternator/Generator cover off if not
Put the Alternator/Generator cover back on and tighten the Allen bolts to 12Nm.
Re: intermittant misfire - wildchild74 - 11-03-15
(11-03-15, 12:50 AM)unfazed link Wrote: Highly unlikely the tensioner is a problem, mostly like a wearing chain or valve clearance to big.
Gasket
Tensioner body
Ball bearing
Springs
M8 your a life saver thanks for the info... why do i need generator cover off so i can turn engine over by hand?? And does the rocker cover need to be off to check clearances i presume yes the reason i ask this is because the mechanic said it could be down to the valve clearances the misfire but its not hard to start.... thanks again
Gaz
Only way to turn the engine over easily and match the timing marks is with the cover off.
Taking out the plugs makes it easier too as there would be no compression to cope with.
with care the Cam cover can be removed with out resorting to removing all the bit the manual says to be removed
Seat off, Tank off, bolt in thermostat housing off.
Pull plugs off and back up to the level of the coils
4 End caps off
8 Cam cover bolts off
Tap the cam cover to unstick it
Take care of the rubber seal it can be reused if not damaged
This is the fiddly bit, trying to maneuver it out, using three hands :lol move the thermostat housing and throttle cable as needed to give a little bit more clearance to take the cover out. It will only come out to one side, I will leave you to discover which  :lol
Plugs out
Alternator Generator cover off
Set timing to T mark as explained in last post
Inlet and exhaust of one of the outer cylinders (1 or 4) can be checked and the inlet or exhaust of cylinder 2 or 3  and  exhaust of 2 or 3 can be checked.
Rotate the crank 360 degrees and check the remaining group.
Lightly Grease the rubber seal  and rubber seals on cam cover bolts before refitting
The same fiddly issue problem when trying to get the cam cover back in place.
Cap bolts are 9Nm
Cam Cover bolts are 10Nm
Re: intermittant misfire - wildchild74 - 13-03-15
Aaarrrrr give me strength this fucking bike is frying my brain now n soz for swearing but so far ive changed plugs,leads,coils, now the carbs and still the problems still there no1 cylinder missing so what do you think folks and ive taken a 22 second video of it and it sounds like clattering at the top of cyl 1 can anyone tell me how upload the vid thanks
Gaz
Bump anyone
Gaz
Re: intermittant misfire - unfazed - 14-03-15
Go to additional options on the post window and click the + sign.
One cylinder ???? sounds like a valve problem maybe an exhaust valve burned or clearance to tight.
Take off the cam cover and first check the valve clearance.
Then again how do you know the replacement carbs are ok.
What way are you counting the cylinders when sitting on the bike. Is your 1 on the left or on the right????
Re: intermittant misfire - wildchild74 - 14-03-15
(14-03-15, 01:23 AM)unfazed link Wrote: Go to additional options on the post window and click the + sign.
Hi m8 sitting on the bike its on the left...starts on the choke ok but off the choke it misses but when i turn it off then restart it starts perfect....ive only got rmt's word that they were ok and i specifically asked if there were any running issues and he said no so i put them straight on and its displaying exactly the same symptoms as b4 but the only difference is that if i put the choke on when its warm now it will run and not cut out where as b4 it would chugg and then cut out i dont know if that means anything...
cant upload vid as its too big
gaz
Re: intermittant misfire - greenman - 24-03-15
Have you checked plug caps, mine died at 40k miles, was a different bike when they were replaced.
Re: intermittant misfire - wildchild74 - 29-03-15
(24-03-15, 07:03 PM)greenman link Wrote: Have you checked plug caps, mine died at 40k miles, was a different bike when they were replaced.
Hi m8 I have just got a new set this weekend. but while I've got the carbs off I'm going to strip out the jets n give em all a good blast thru with carb cleaner and give them a general clean as when I drained them the petrol was full of tiny black bits. I put the fazer on the bay last Sunday n was looking at ninjas but I gave the fazer a clean n started it n for that first minute or two running on the choke apart from the slight misfire it sounded lovely n then thought I can let it go for peanuts so took it off eBay n decided to keep it so I'll keep you all posted
Gaz
