Think my engine is going to die :( - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Think my engine is going to die :( (/showthread.php?tid=70255) |
Re: Think my engine is going to die :( - darrsi - 16-09-14 This noise sounds very familiar to me from years back. Is it definitely the clutch area, i could be well off here but what about the water pump? The fins can break causing noises like that and it could explain the overheating. I'm hearing two things going on, that buzzing noise, plus a poor sounding engine noise as well. Just out of curiosity, check your expansion tank and see if the level is correct, or at least how you last remember it? If it all looks normal just ignore me and i will quietly go away. :rolleyes Re: Think my engine is going to die :( - Paulfzs - 16-09-14 Its hard to tell where its coming from, if i put my ear up to the clutch case there is a tapping noise but doesn't sound the same as the knocking when i open the throttle.. best way to describe it is it sounds like a con rod bashing around the cylinder. my zxr 750 sounded the same when the cct went though... the shells where knackered. Re: Think my engine is going to die :( - darrsi - 16-09-14 I'm thinking a trip to a mechanics is a bit overdue mate, noises like that can only make things worse. I know it's always nice to try and sort things yourself but the longer you leave it the more damage you might be doing.
Re: Think my engine is going to die :( - Paulfzs - 16-09-14 So... i figured its a pretty bad problem but riding 5 miles letting it cool then going 5 more to a friend whos a wizzard with bikes and owns about 30 would be fine seeing as when its cool its perfectly fine... Managed to get 15 miles with no signs of rattle or odd noises.. i thought it had cured itself. Got most of the way untill i hit the motorway and hello screaming engine and down to 30mph... pulled over and got recovered... got to friends got cover off and camchain seems to be fine... rattle sounds like its coming from the cylinder ![]() Left bike there and had a £22 train ride back home. Now im stuck what to do... do i take the engine out strip it and try fix it or do i cut my losses and sell as spares or repair. Re: Think my engine is going to die :( - His Dudeness - 17-09-14 Depends on your situation. If you've got a bit of time sure you might as well strip it and see what's going on inside. You could get a used head and cams cheap enough if that's the problem or if you need it for everyday transport and you don't have the time to fix it maybe go down the replacement engine route, they're fairly reasonably priced you might even get one on here. Re: Think my engine is going to die :( - Paulfzs - 20-09-14 Bottom end is dead. New bottom end it is! Re: Think my engine is going to die :( - unfazed - 20-09-14 The most common reason for the crank going on a fazer is that it has been down the road on it side with the engine revving high before the fuel runs out. Re: Think my engine is going to die :( - Paulfzs - 20-09-14 Who knows what happened to it, nevermind atleast ill have peace of mind once its done Re: Think my engine is going to die :( - unfazed - 20-09-14 Are you going to fit another engine? Repairing it is a very expensive option. Re: Think my engine is going to die :( - Paulfzs - 21-09-14 I was going to fit a new bottom end as theres like 5000 on ebay for <£90 but a guy not far from me has an 03 fzs engine with only 23k miles fsh and valves just been done for £250. for peace of mind i think im going to replace the whole engine, my fzs is currently on its 2nd engine with unknown mileage so the top end may well be almost dead too. Re: Think my engine is going to die :( - unfazed - 21-09-14 (21-09-14, 03:02 AM)Paulfzs link Wrote: I was going to fit a new bottom end as theres like 5000 on ebay for <£90 Good call :thumbup Re: Think my engine is going to die :( - Paulfzs - 21-09-14 Im slightly nervous about doing it though, ive done full rebuilds on single cylinders and even truck engines but never done a big bike engine, i blew the bottom end on my old zxr 750 and got as far as the cylinder head off to inspect and gave up. I do have a friend whos helping me do it, hes a god of bikes but hopefully this isn't too hard to swap over. Re: Think my engine is going to die :( - lincs1963 - 21-09-14 (11-09-14, 12:33 PM)tweetytek link Wrote: So.. I'm not like minded as paul, no way, and I've personally met my like minded people on here including ex police officers and instructors, who would share my view. So yep, were like minded but not your like mindedHello mum, when did you sign up
Re: Think my engine is going to die :( - unfazed - 21-09-14 (21-09-14, 05:45 PM)Paulfzs link Wrote: Im slightly nervous about doing it though, ive done full rebuilds on single cylinders and even truck engines but never done a big bike engine, i blew the bottom end on my old zxr 750 and got as far as the cylinder head off to inspect and gave up. Most difficult part is taking the engine out of the frame and it comes out the right hand side In addition to what the manual says, I found the that removing the Oil filter and the Thermostat housing makes it easier Good luck :thumbup Re: Think my engine is going to die :( - Paulfzs - 25-09-14 Many thanks ill remember that ![]() Struggling to make final funds for engine as ive just paid rent but only £50 away so hopefully will be end of the week start of next Re: Think my engine is going to die :( - Paulfzs - 09-10-14 Finaly got round to getting engine on its way, will be here saturday so i will be doing the engine change then.... Worrying like mad about the exhaust studs though! |
