[SOLVED] "is this tank slapper"? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: [SOLVED] "is this tank slapper"? (/showthread.php?tid=69765) |
Re: [SOLVED] "is this tank slapper"? - unfazed - 02-08-14 (31-07-14, 07:07 PM)keratos link Wrote:[quote author=unfazed link=topic=14162.msg160549#msg160549 date=1406829967]Eh? English? [/quote] That was the Queens English? what English do you require :lol Re: [SOLVED] "is this tank slapper"? - keratos - 02-08-14 Just me being non mechanical minded and not understanding I've since googled and now comprehend :o Re: [SOLVED] "is this tank slapper"? - unfazed - 02-08-14 :thumbup
Re: [SOLVED] "is this tank slapper"? - Fazafou - 02-08-14 (02-08-14, 02:11 PM)keratos link Wrote:mine has a top box too. Glad you're happy now ![]() Re: [SOLVED] "is this tank slapper"? - keratos - 02-08-14 (02-08-14, 08:34 PM)Fazafou link Wrote:[quote author=keratos link=topic=14162.msg160796#msg160796 date=1406985079] Glad you're happy now [/quote] I wouldnt say I'm happy but I just live with it as recommended by wise foccers here and my trusted shop mechanic Re: "is this tank slapper"? - paulchucky - 03-08-14 (28-07-14, 09:53 PM)unfazed link Wrote:Don't think it is a serious problem, mine was doing it since its first tyre change and still does it 84000miles later. no way take my hands off at 100mph n not a twitch if it wobbles theres sumet not right ! find it sort it Re: "is this tank slapper"? - keratos - 03-08-14 (03-08-14, 09:28 PM)paulchucky link Wrote:... like i said above... http://foc-u.co.uk/wiki/index.php?title=Front_Wheel_Wobble_-_description,_and_possible_causes Re: [SOLVED] "is this tank slapper"? - unfazed - 03-08-14 Point appears to have been missed, it only appears to happen around 40mph, it does appear to happen above 50 or below 30. On any bike I have ridden including my own it has always been around the 40mph mark. This issue has been around for years and frame design plus the harmonic resonance of the components involved can exacerbate it. Watch the chatter problem in racing which is exacerbated by super stiff frames and is caused they think by harmonic resonance. Yamaha changed the stiffness of the frame in MotoGP to try and reduce the effect as changing the stiffness changed the point of harmonic resonance at a given speed An unbalanced wheel can cause it and I do not mean unbalanced with a tyre on, but unbalanced bare wheel. :eek Many standard wheels are out of balance by up to 30 grams from the factory due to manufacturing tolerances. :eek On one particular fazer I checked, the imbalance of the bare wheel with discs attached was 5 grams. It did not have the problem. My original front wheel with discs attached was 25 grams out, but the new wheel replaced after an accident (insurers paid) was 12 grams out without the discs and was 14 grams out with the discs on and the problem is not as pronounced with this wheel. Balancing wheels is not a perfect science as you cannot add weight to the exact point it is required. Unless you can get a machine to detect the inbalance of either side of the rim like the wider car wheels there will always be the shake possibility on the fazer. A super quick steering bike is much more prone to the problem (which is why many race rep bikes with quick steering use a steering damper) and the 600 as a pretty quick steering bike it is more prone to it.. It is quite possible that those who have fitted a 120 section front tyre may not suffer from the problem as it slows the steering, I am surmising as I have never checked it. Re: [SOLVED] "is this tank slapper"? - keratos - 03-08-14 I get it at any speed. starts off as a gentle wobble but leave it along and it gets into the resonance oscillation we call a slapper anyway, been checked out and safe to ride cant be that bad as two fingers gently on the right or left grip stops it. I'm riding regardless now Re: [SOLVED] "is this tank slapper"? - unfazed - 04-08-14 Out of curosity, next time you change the front tyre ask the mechanic to check the wheel balance without the tyre and all balance weights off. What tyres are you using? I found the sports tyres were worse than sports touring tyres as they sharpened the steering, but I prefer the sharper steering. It does not bother me, since there is no serious mechanical issue Re: [SOLVED] "is this tank slapper"? - keratos - 04-08-14 (04-08-14, 12:02 AM)unfazed link Wrote:Out of curosity, next time you change the front tyre ask the mechanic to check the wheel balance without the tyre and all balance weights off. just had it balanced, but with tyre on, kind of misses the point with it off I would have thought. BT10s - whatever designation they are (sports/tourer/tortoise) Re: [SOLVED] "is this tank slapper"? - unfazed - 04-08-14 Harmonic resonance of different materials. Re: [SOLVED] "is this tank slapper"? - keratos - 04-08-14 (04-08-14, 04:10 PM)unfazed link Wrote:Harmonic resonance of different materials.Mmm. So can a specific tryre reduce this phenomena ? |
