Charging system issues - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Charging system issues (/showthread.php?tid=66020) |
Re: Charging system issues - unfazed - 23-10-13 (23-10-13, 09:37 PM)Doddsie link Wrote: Im lost, Ill just stick to cleaning mine!!Any chance you could come and clean mine :rollin Re: Charging system issues - Doddsie - 23-10-13 Any chance you could come and clean mine :rollin Ill trade ya next time i have an electrical problem!!
Re: Charging system issues - 69oldskool - 23-10-13 :lol :lol :lol Re: Charging system issues - 69oldskool - 23-10-13 (23-10-13, 09:44 PM)BorisTheThird link Wrote: [quote author=69oldskool link=topic=10406.msg108988#msg108988 date=1382560242] Mr Haynes also says "caution: never disconnect the battery cables from battery whilst the engine is running...." Hmmm.....just maybe he's onto something. :evil However, Mr Yamaha says & he should know i guess )http://foc-u.co.uk/index.php?action=downloads;sa=view;down=8 In the official factory manual,yes you can test the rectifier, download & have a good read of the electical section. Whatever "this" was in last post it's not showing on my computer.??? Not being funny Boris, but i'd be more bothered 'bout fixing my bike than debating every point brought up, there a helpful lot here,& they're only trying to help. :\ [/quote] Thanks, not trying to be annoying, just trying to understand how things work (i cant fix the bike till tomorrow now so m stuck inside on the pc )and in the last post i was trying to post the first picture in this http://webpages.charter.net/jrandall/vrr/vrr_upgrade.htm [/quote] Ok,no worries. & yes similar to that diagram. Re: Charging system issues - Andy FZS - 23-10-13 Well I'm learning things I hope I'll never need to know, but then I know lots of things that nobody needs to know. Re: Charging system issues - BorisTheThird - 23-10-13 (23-10-13, 09:52 PM)69oldskool link Wrote: [quote author=BorisTheThird link=topic=10406.msg108998#msg108998 date=1382561072] Mr Haynes also says "caution: never disconnect the battery cables from battery whilst the engine is running...." Hmmm.....just maybe he's onto something. :evil However, Mr Yamaha says & he should know i guess )http://foc-u.co.uk/index.php?action=downloads;sa=view;down=8 In the official factory manual,yes you can test the rectifier, download & have a good read of the electical section. Whatever "this" was in last post it's not showing on my computer.??? Not being funny Boris, but i'd be more bothered 'bout fixing my bike than debating every point brought up, there a helpful lot here,& they're only trying to help. :\ [/quote] Thanks, not trying to be annoying, just trying to understand how things work (i cant fix the bike till tomorrow now so m stuck inside on the pc )and in the last post i was trying to post the first picture in this http://webpages.charter.net/jrandall/vrr/vrr_upgrade.htm [/quote] Ok,no worries. & yes similar to that diagram. [/quote] Thanks (23-10-13, 09:53 PM)Andy FZS link Wrote: Well I'm learning things I hope I'll never need to know, but then I know lots of things that nobody needs to know..... Im learning thing i really should know, i deal with these (ish) in my job - just 50kv AC - 650v DC ones :eek Re: Charging system issues - CRH - 23-10-13 (23-10-13, 09:53 PM)Andy FZS link Wrote: Well I'm learning things I hope I'll never need to know, but then I know lots of things that nobody needs to know....hope t fk it doesnt involve paul and dolly" :b :b :b :b :b Re: Charging system issues - Andy FZS - 23-10-13 When it comes to Paul and Dolly there are lots of things I don't want to know at my young age;D Re: Charging system issues - Paul - 24-10-13 In the old brit bike world lots of people run bikes without batteries, they use the Boyer ignition box set up. I have a Honda Innova which will start and run with no battery on it, but I caveat that with you have to use the kick start and the clocks don't work unless you connect the battery. Oddly enough you can take the battery off and kick it up and it starts just as easily as if it had a battery on it. And the main headlight is on permanently (you can't turn it off). Although maybe it's been specifically designed like that for places where there is no way of charging a battery up. Re: Charging system issues - Fazerider - 24-10-13 FWIW, the generator on the Fazer (and most bikes) is a magneto i.e. an alternator using permanent magnets. The term alternator just means ac generator, but is generally used to refer to those that use electromagnets rather than permanent ones to provide the magnetic field: they're bulkier but more efficient and are what cars use. In theory, disconnecting the battery while the engine is running needn't cause a disaster. The regulator will continue to limit the peak voltage and, while the rectified ac will be very lumpy without a battery, the ignition should cope. However, it's not something I'd care to try and I agree with all the advice you've been given: as a diagnostic technique it stinks. If the regulation had failed volts could rise high enough to nuke the ignition unit and instruments. The stator coils should measure 0.36 to 0.44 ohms so yes, yours sound about right (you'll probably be within spec if you subtract the measurement you get when shorting the multimeter leads together). If the battery charger you used as a supply is a simple transformer and rectifier type, then the volts dipping to zero fifty or a hundred times a second would probably have starved the ignition and that is what stopped the engine in your test. Provided there's decent continuity in the rest of the charging circuit then I'd agree the rectifier is probably to blame. The easiest way to check is by substitution. I've never tried testing mine, my Yamaha manual doesn't give details, but if is a simple bridge rectifier and shunt regulator arrangement it should be easy to check. On the other hand, if it uses SCRs in the bridge to reduce the power the thing has to dissipate when the magneto is at full output I'll agree with Mr Haynes that it's too complicated to test with a multimeter. Re: Charging system issues - darrsi - 24-10-13 (24-10-13, 10:49 AM)Fazerider link Wrote: FWIW, the generator on the Fazer (and most bikes) is a magneto i.e. an alternator using permanent magnets. The term alternator just means ac generator, but is generally used to refer to those that use electromagnets rather than permanent ones to provide the magnetic field: they're bulkier but more efficient and are what cars use. Yeah......that's what i was gonna say :thumbup Re: Charging system issues - Andy FZS - 24-10-13 I find it's all so obvious once somone else has said it
Re: Charging system issues - CRH - 24-10-13 (24-10-13, 11:23 AM)darrsi link Wrote: [quote author=Fazerider link=topic=10406.msg109067#msg109067 date=1382608191] Yeah......that's what i was gonna say :thumbup [/quote] (24-10-13, 03:56 PM)Andy FZS link Wrote: I find it's all so obvious once somone else has said it....yes me too ...just wanted unfazed and fazerider to confirm what i realy knew already?...but like darrsi i dont like bragging :rolleyes ....that bloke haynes" knows fk all :\
Re: Charging system issues - 69oldskool - 26-10-13 Got any further on diagnosis & cure yet Boris? Re: Charging system issues - 69oldskool - 26-10-13 How's this sound for testing the reg/rect? Disconnect Red output lead,stick mulitmeter across output on 20v ish a/c voltage range~ run bike, but keep revs to a minimum, if ac voltage shows, rectifier part is swiss cheese~ chuck in nearest wheely bin. If no a/c switch to dc voltage range~ & check it's in the ballpark of 12-15v.ish. Stop engine &Reconnect output lead,then test regulator circuit as per factory manual with engine running. Please DO NOT try 'til one of our more knowledgeable members has commented~ It's a plan, but it may be flawed
Re: Charging system issues - BorisTheThird - 26-10-13 oh yes, sorry for the lack of response, got the new rectifier on which fixed it the charging until... I noticed a sparks from the left just under the seat (the wires were still displaced and cover off from testing the stator). 3 or 4 of these wires had become bare from rubbing against the frame (i think) and no shorting to each other/earth. inc wires to the stator. :eek so in better news, i think i may have found what killed my reg/rec, going to spend tomorrow pulling out the loop and replacing these wires :b Re: Charging system issues - unfazed - 27-10-13 (26-10-13, 07:11 PM)69oldskool link Wrote: How's this sound for testing the reg/rect?You theory is good but flawed unfortunately, disconnecting the output lead could damage the regulator as the battery is a functional part of the charging circuit. There is a simpler way as mentioned in one of my previous posts and no disconnection of any wires required. Set the meter to AC and with everything connected start the bike and check the voltage between the white wires of the alternator this is done 3 times accross the different wires to check all the alternator coils; (push the meter leads (carefully) into the back of the plug) it should read around 18 to 20 volts AC. Revving the engine to 2000 revs will increase the AC voltage dramatically, if this is the case then the Alternator is working. If this does not happen the alternator is faulty. [size=1em]With the engine running at tick over, set the meter to DC and the voltage measured across the battery should read over 12v and go up to an absolute maximum of 14.4 (may be a little bit less) when the engine is revved over 5000 revs. If the voltage does not increase and you have 18v AC + from the alternator then the regulator is faulty. If the voltage goes over 14.4 volts then the regulator is also faulty.[/size] [size=1em]Glad to see Boris appears to have found the problem.[/size] Re: Charging system issues - Torque - 29-01-14 Stupid question, I've bought new rectifier, but where should I look on my FZS600? Is it somewhere near horn? Or rear seat? Re: Charging system issues - unfazed - 30-01-14 Under the left hand fairing infill. |
