quiet when cold, rattles like mad when warm ?? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: quiet when cold, rattles like mad when warm ?? (/showthread.php?tid=62999) |
Re: quiet when cold, rattles like mad when warm ?? - reddave101 - 31-03-14 (31-03-14, 01:08 PM)markaboot link Wrote: [quote author=reddave101 link=topic=7375.msg138008#msg138008 date=1396121728] interesting! would be worth doing a little how to on this or at the least a few pics please [/quote] Will Upload pics Later. A little how to. I managed to find a valve stem at work with the same thread and size as my oil filler cap, removed the bearing from inside the valve as it was inlet and not outlet( would suck in but not blow out) which left the valve open.. Simply went shop bought a fuel hose(in red to match bike), air filter with stem on and just screwed one side of the pipe to the filler cap end and the other side to the filter and cable tied it along the frame and behind the pillion foot peg(you can smell the fumes coming out, so rather behind me). Crankcase breather- removed the breather pipe and bought a longer peice. Had trouble getting the right diameter, so just soaked the biggest hose I could get in boiling water to relax the rubber and fitted snugly over the crankcase flute and then just routed it through the same restraints as the fuel overflow pipe down under the bike.. Air box.- Very simply just removed the L union and put a rubber blank gromit into the hole as didn't want extra air getting in. Does throw mixture slightly out but very easy to make the necessary adjustments to compensate... Also removed the blank plate inside the airbox to allow the fresh air to circulate around the filter better.. Now sounds like a turbo under the tank as the air is sucked in lol. Everything seems to respond better with these very simple mods,. Throttle is more responsive, fuel economy is better, and the annoying tick is gone. Also power delivery is smoother.. |
