stuttering fzs 600 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: stuttering fzs 600 (/showthread.php?tid=57718) |
Re: stuttering fzs 600 - red98 - 26-08-12 working yesterday but found some fettling time in the garage .....cleaned up the block and fitted gasket , head and torqued in two stages too 35 nm ...day off today with a few jobs to do around the house :\ but will try to sneak out to the garage to fit the cams
Re: stuttering fzs 600 - red98 - 26-08-12 bit more work on the fazer today fitted the cams and set the timing refitted the cam cover and also the geni cover ......starting to look like a complete bike now
Re: stuttering fzs 600 - CRH - 26-08-12 not long now then matey? .......got a good feeling bt this one?..not long now before we hit that ...RED"..line!!!!!!!!! 8)
Re: stuttering fzs 600 - red98 - 26-08-12 (26-08-12, 09:08 PM)CRH link Wrote: not long now then matey? very good crh :rollin carbs on next after ive adjusted the mixture and then all the bits and pieces just been reading the darrsi post.........thats been in the back of my mind from day one as replaced the filter shortly before i noticed the stutter :rolleyes Re: stuttering fzs 600 - CRH - 26-08-12 yes that was mentioned wasn,t it?...something about having a air tight seal around it to wasn,t it?..... :rolleyes Re: stuttering fzs 600 - red98 - 26-08-12 (26-08-12, 09:18 PM)CRH link Wrote: yes that was mentioned wasn,t it?...something about having a air tight seal around it to wasn,t it?..... :rolleyes thats right.....i have a pattern filter in there at moment looks as good as original,fits well ....iam thinking of treating it to a k+n,but a few more things to check before i do that
Re: stuttering fzs 600 - CRH - 26-08-12 well,ive got a KnN in mine and it sounds lush when you give it some!!...lovely induction roar, accompanied by a harpoon race can!!..so i would recomend you get one?....
Re: stuttering fzs 600 - red98 - 27-08-12 (26-08-12, 09:29 PM)CRH link Wrote: well,ive got a KnN in mine and it sounds lush when you give it some!!...lovely induction roar, accompanied by a harpoon race can!!..so i would recomend you get one?.... ok thats recomended by DARSSI and CRH [size=78%]...... i`ll get the bike back together and treat it to a k+n filter [/size]
Re: stuttering fzs 600 - red98 - 27-08-12 more garage time this morning.......carbs,checked the mixture.......4 turns out :eek .....as ive stated before i`ve owned the bike for 10 yrs,9000 miles when bought now on 40000,carbs not been touched in my ownership and main dealer service records before that :\ standard mixture settings should be 2 turns out :eek i was going to richen by 1/2 turn,but left as is and re-fitted 1 1/12 hrs this morning,struggled re-fitting the carbs this time :\ ....untill i realised its a lot easier mounting onto the air box rubbers and securing with the julibee clips and then sliding into cylinder head rubbers ..........i know that already,senior moment as iam at that funny age
Re: stuttering fzs 600 - red98 - 27-08-12 (26-08-12, 04:38 PM)red98 link Wrote: bit more work on the fazer today forgot to mention time taken on this post.....took my time getting the timing right,turned over on the crank and re-checked a few times........3 1/4 hours
Re: stuttering fzs 600 - CRH - 27-08-12 yes red!...you still got approx 2 1/2hrs left!! .....4 turns out you say?....shit!!! thats alot int it?...chkd mine the other day and mine where ...cyl,s 1 plus 4...2 1/2 turns out...and 2plus 3 ...2 3/4 turns out...so i tweaked em bk to 2 1/2 ...and it defo made motor smoother on idle!! ...what you been getting mpg wise then?....i average 52 taking it easy :rolleyes .....worst i got was 40.. ps you changing oil and filter b4 you crack her up??....allways wise i recon cus of bits left behind you dont allways see .....best being safe than sorry!!!!!
Re: stuttering fzs 600 - red98 - 27-08-12 (27-08-12, 11:54 AM)CRH link Wrote: yes red!...you still got approx 2 1/2hrs left!! 4 turns was a bit of a surprise :eek ..............59 mpg before strip down no problems there
Re: stuttering fzs 600 - red98 - 27-08-12 another 1 1/2 hours to add to the total,just fitted all the bits and pieces all i need to do now is top up the coolant level....job done oh...............forgot to mention............brum,brum,brrrrrrrrrrrrrrrrrrrrrrruuuuummmmmmmmmmmmmmm [size=78%] [/size]
Re: stuttering fzs 600 - CRH - 27-08-12 What?..it runs??????? :b .......looks like a trip out then this afto?? ........
Re: stuttering fzs 600 - CRH - 27-08-12 1 hour remaining ?....just time to rip off ya dustbin lid n make yaself a big fat medal t hang round ya neck me thinks!!!!!!! :b ....got a good feeling bt this one?
Re: stuttering fzs 600 - Dead Eye - 27-08-12 (27-08-12, 08:27 AM)red98 link Wrote: [quote author=CRH link=topic=2066.msg36520#msg36520 date=1346012998] ok thats recomended by DARSSI and CRH [size=78%]...... i`ll get the bike back together and treat it to a k+n filter [/size] [/quote] Definitely recommend the K&N as well Got one on mine but having replaced the entire exhaust system at the same time I can't comment exactly on it precisely - the entire system has been running like a dream though. Can't wait to get mine back tomorrow
Re: stuttering fzs 600 - darrsi - 27-08-12 I've got replaced stainless down pipes and a what's virtually a race can, and it's always been just fine, but the K&N has made it noticeably better :b (not including the latest hiccup obviously) Sounds a tiny bit different as well. Re: stuttering fzs 600 - red98 - 27-08-12 had an afternoon with mumsy today as 80th birthday,good day ,quized her and her elderly friends on the stutter problem and all i got was blank looks :rolleyes ........bike fired up a treat this morning no problem.....inlet shims were fine,exhaust i increased by 1 size (0.05 mm) did`nt think i would notice the difference,could not have been more wrong........top end is as quite as something very quite .....not a single rattle or knock,even on first start up well pleased with that 8) tick over is a bit lumpy now so will re-balance the carbs...need to do a bit of homework on this to understand ....HG :o .......as dont know what this is yet....but i do know its quite crucial to getting the best from the bike anyone know about this HG thing ?..........................
Re: stuttering fzs 600 - red98 - 27-08-12 (27-08-12, 02:57 PM)CRH link Wrote: 1 hour remaining ?....just time to rip off ya dustbin lid n make yaself a big fat medal t hang round ya neck me thinks!!!!!!! :b ....got a good feeling bt this one? cheers matey shame i have a plastic bin,but will wear it anyway ....need to get some coolant and balance the carbs and then it will be test ride time
Re: stuttering fzs 600 - CRH - 27-08-12 dont understand this HG meself red?...but think its something to do with pull of vacuum!!..ie, a maximum and minimum between cylinders?....
