Re: what did you do with your fazer today ? - hairnet - 06-06-15
two and a half miles a minute today
cant believe not much buffeting
Re: what did you do with your fazer today ? - devilsyam - 06-06-15
took hedgtrimmer 4 panel to paint for a speedblock scheme with a twist
Re: what did you do with your fazer today ? - red98 - 06-06-15
(06-06-15, 01:16 AM)hairnet link Wrote: two and a half miles a minute today
must be nice to have your own private test track,i have to make do with the drive  Wink .........so,what mods you done to the 600 than  Smile
Re: what did you do with your fazer today ? - nick crisp - 06-06-15
(06-06-15, 08:37 AM)devilsyam link Wrote: took hedgtrimmer 4 panel to paint for a speedblock scheme with a twist
Hedgetrimmer no.4 already had a speedblock paint scheme with a "twist"  :lol
Yeah had added foliage
Re: what did you do with your fazer today ? - esetest - 06-06-15
Serviced the EXUP valve , and checked cable adjustment , stripped , cleaned and greased and reassembled .
pics.
pics.
Replaced the front brake pads , a fairly easy job considering i have never changed pads before .
Re: what did you do with your fazer today ? - riedrider - 06-06-15
Mounted a new chain for visual resaons and to try out my new Kellermann chain tool  Smile
The old chain has rusty spots and I do not like that.
I changed only the chain since the bike has only 11200 miles the sprockets are in quite good condition.
The Kellermann tool works great. I did that job the first time and the result is perfect. According to DID the flare diameter should be 5,5 to 5,9 mm and mine have 5,7 mm
old chain
[Image: 2e1ul9x.jpg]
Kellermann tool
[Image: 29d8cgo.jpg]
joined new chain
[Image: x211xl.jpg]
Re: what did you do with your fazer today ? - pilninggas - 06-06-15
Just had a few relaxing hours cleaning my FZ1S (also removed the luggage racks so I can repaint it before I go on holiday - rusty/flaky paint looked awful  :pokefun )
Looking spanking now:
[Image: 20150606_165715.jpg]
[Image: 20150606_165707.jpg]
Re: what did you do with your fazer today ? - Billy Balthorpe - 06-06-15
Removed the radiator to tackle the exhaust removal and found this.
[Image: DSC_0733.jpg]
[Image: DSC_0734.jpg]
What a mess.
[Image: DSC_0737.jpg]
With much hammering and chiselling the exhausts finally came off, leaving some very manky looking studs.
[Image: DSC_0739.jpg]
Does anyone have the top cover off the oil cooler thingy and the pipe in this next pic, they were both so corroded that the spigot on the oil cooler just fell off and while I was scarping rust off the coolant pipe my screwdriver went straight through it.
[Image: DSC_0740.jpg]
See
[Image: DSC_0742.jpg]
Engine cleaned off prior to paint.
[Image: DSC_0745.jpg]
Painted. Ok so it doesn't look so good but its better than it was.
[Image: DSC_0747.jpg]
Spent all day doing that lot, now ive got to buy the coolant pipe, the top off the oil cooler, a new frame bar thing (which runs across the front of the engine) some downpipes with a working EXUP hopefully, EXUP cables, exhaust gaskets, stainless studs, blah, blah, blah.
Re: what did you do with your fazer today ? - slappy - 06-06-15
I repair stuff at work sometimes that have been at the bottom of the north sea that look better than those exhaust nuts and studs!
And I get  upset about some rust spots on my chain  :rollin
(06-06-15, 07:44 PM)slappy link Wrote: I repair stuff at work sometimes that have been at the bottom of the north sea that look better than those exhaust nuts and studs!
Yeah I know, I couldn't make it look like that if I really tried.
All the studs came out except one tho, penetrating oil and a good whacking on the end to try to break the grip, then used my barrel stud extractor and they came right out. The one that snapped was drilled out and tapped, so job done.
Re: what did you do with your fazer today ? - unfazed - 06-06-15
Washed it  Smile
Quote:Washed it  [img alt=Smile]http://foc-u.co.uk/Smileys/efocicon/smile.gif[/img]
:eek too much water can cause corrosion  :rollin
Better dry it then  :'(
Re: what did you do with your fazer today ? - noggythenog - 06-06-15
(06-06-15, 09:55 PM)unfazed link Wrote: Better dry it then  :'(
I think nick has an on bike leaf blower attachment he could sell you :lol
As far as i can remember that's the first pic ive seen of your bike Unfazed........looks pretty fast....well it is mostly red........how much drop on the yokes...20mm????
Re: what did you do with your fazer today ? - Dead Eye - 07-06-15
Got out on the bike this morning as the weather is utterly fantastic Big Grin
Enjoyed doing a bit more exploring and generally just finding roads that I've been along before. Was out for 2 1/2 hours and covered about 100 miles but I have no fucking idea where the hell I went Tongue
