None starter - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: None starter (/showthread.php?tid=82061) Pages:
Re: None starter - Dinger1962 - 18-10-20 imoh opinion i would check its not drawin air on the inlet rubbers o rings can dry out rubbers can crack even the balance port caps can leak through time also small inline filter situated at carb end of inlet hose can clog easy -- Re: None starter - cojonesdeloro - 19-10-20 Thanks again for suggestions lads, I bought a 15ltr ultrasonic cleaner and the carbs got stripped then have been in for several cleanings (they are mint now) the main problem was the carb icing circuit, the water lines were solid with gunge, took hrs of fettling but they are now clean. I have some strange wiring from the battery that I think may have been an alarm or immobiliser in the past ( extra fuse holder) I'm wondering if this could be at fault also. still looking. have also ordered a compression testing kit, what sort of pressure should I be looking for? not beat yet 8) cheers. Daz. |
