FZ1 2nd Generation Brakes upgrade - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: FZ1 2nd Generation Brakes upgrade (/showthread.php?tid=81796) Pages:
Re: FZ1 2nd Generation Brakes upgrade - b1k3rdude - 06-07-20 (06-07-20, 01:52 PM)Bikebud link Wrote: I going to attempt this. Do i need to loosend the fluid reservior cover first?I never had to for either of the other times I have used cable-tie the lever back to the bar work-around in the past, so I would say no, there is no need. The air thats trapped in the system will eventually make its way upto the MC, displacing a little bit of brake fluid in the process, which then loweres the level by a small amount. Oh and I recommend having the bike on the side stand while you do the above, so the MC is the highest point in the brake system and provides less restrictive path for the air bubbles to travel (It cant hurt). Re: FZ1 2nd Generation Brakes upgrade - Gnasher - 07-07-20 Tying back the lever on an ABS system will help remove air trapped in the line down to the pump, it will have little or no effect on air trapped in or the other side of it. If your ABS system is spongy at the level and there's no other issues as I outlined earlier, you've got air in the system and the only way to clear it is to bleed it. No amount of get around's is going to sort it and it will just get worse, get the system bled by someone who knows what they're doing. Re: FZ1 2nd Generation Brakes upgrade - b1k3rdude - 07-07-20 (07-07-20, 08:08 AM)Gnasher link Wrote: No amount of get around's is going to sort it and it will just get worse, get the system bled by someone who knows what they're doing.2 Different places I went to were competent, yet neither were able to successfully bleed my bike/s. hence my home mechanic approach. Ive read that for some bike there is a diagnostic connector for manually triggering the pump to help purge said air bubbles, is this the case for the FZ1 or is the system just to old and agricultural. I've just spoke to Yamaha Tech UK, and they will call me back shortly once the tech guy has had a chance to have a look at his system. Hopefully they will be able to give me the procedure to bleed the FZ1 correctly etc. Re: FZ1 2nd Generation Brakes upgrade - b1k3rdude - 07-07-20 Ok, so there isn't any special way to bleed the brakes on the FZ1 according the Yamaha tech. The ABS tech on the FZ1 was designed and made by Yamaha, As Gnasher commented a few posts back. He suggested the following 2 methods though -
Re: FZ1 2nd Generation Brakes upgrade - Gnasher - 07-07-20 The issue with ABS is the pump/modulator, if whomever has worked on the system has caused agitation of the fluid by shaking, over pumping or just bad practice, you'll get micro bubbles. Just bleed the system as normal but slowly and deliberately, gravity is your friend here, so is a good vacuum bleeder with experience and skill. I've said it countless times, if you're not sure or had a go and were not successful, take it to someone who knows how. Brakes aren't DIY if you don't know what you're doing, many think they do until they get on a bike with proper bled brakes :eek Trying to save a few £ could cost you dearly, I kid you not! Re: FZ1 2nd Generation Brakes upgrade - b1k3rdude - 07-07-20 (07-07-20, 10:49 AM)Gnasher link Wrote: has caused agitation of the fluid by shaking, over pumping or just bad practice, you'll get micro bubbles.Contextually I don't grasp how or why would someone would do this, the ABS unit would be bolted to the bike. But with regard to over-pumping, how exactly..? (07-07-20, 10:49 AM)Gnasher link Wrote:
Re: FZ1 2nd Generation Brakes upgrade - Gnasher - 07-07-20 (07-07-20, 01:26 PM)b1k3rdude link Wrote: [quote author=Gnasher link=topic=26278.msg317519#msg317519 date=1594115374]has caused agitation of the fluid by shaking, over pumping or just bad practice, you'll get micro bubbles.Contextually I don't grasp how or why would someone would do this, the ABS unit would be bolted to the bike. But with regard to over-pumping, how exactly..? (07-07-20, 10:49 AM)Gnasher link Wrote:
Mate the questions you're asking are exactly why brakes aren't DIY. I'm sorry but most home mechanics are just getting away with it, I'm not entering into an argument here, or trying to disrespect people. I've seen hundreds of examples of DIY on brakes and it's frightening. :eek :rolleyes I'm happy to help but too a point, what you can never underestimate is, experience and skill, that can't be learnt via internet forums. If your brakes are spongy after they've been worked on by a professional who you've paid, take the bike back and give him/them an opportunity to correct the work. If they refuse demand you money back, don't go trying to sort it yourself. Re: FZ1 2nd Generation Brakes upgrade - b1k3rdude - 07-07-20 (25-06-20, 10:13 PM)b1k3rdude link Wrote: cable-tie the brake lever back to the bar for 2 evenings.Here is a video of a guy doing exactly the same thing - https://youtu.be/kvIxxgvllLA And another video about bleeding ABS motorcycle brakes, who mentions the Syringe and the cable-tie methods - https://youtu.be/1iSN2vc5-b0 (07-07-20, 01:55 PM)Gnasher link Wrote: If your brakes are spongy after they've been worked on by a professional who you've paid, take the bike back and give him/them an opportunity to correct the work. If they refuse demand you money back, don't go trying to sort it yourself.As Ive mentioned, been there done that. And in the end, there was no choice - I had to do it myself. But I appreciate what your saying and also don't want to get into a bargy about it. @Bikebud, let us know once you get the brakes bled and how etc. Re: FZ1 2nd Generation Brakes upgrade - Gnasher - 07-07-20 (07-07-20, 02:09 PM)b1k3rdude link Wrote: As Ive mentioned, been there done that. And in the end, there was no choice - I had to do it myself. I don't understand, if you paid for someone to bleed you brakes and they were spongy, why was there no choice? Re: FZ1 2nd Generation Brakes upgrade - b1k3rdude - 07-07-20 (07-07-20, 02:59 PM)Gnasher link Wrote: I don't understand, if you paid for someone to bleed you brakes and they were spongy, why was there no choice?In both instances the bike was my only form of transport, so it needed to be working, hence why I ended up fixing it myself. And had I not being able to fix it myself, it would have gone back for said shop/s to do the job. And only because it was brought up a few posts ago, as bleeding the brakes was only part of the work being done. I did get a reduction in the bill due to the brakes being spongy in both instances. But as the cable-tie method work both times and has always worked in the past, I will continue to plan ahead when working on a brake systems so I can use said method as a backup plan. Back on topic, lets wait and see how Bikebud gets on with his bike. Re: FZ1 2nd Generation Brakes upgrade - Gnasher - 08-07-20 (07-07-20, 10:23 PM)b1k3rdude link Wrote: [quote author=Gnasher link=topic=26278.msg317529#msg317529 date=1594130378]I don't understand, if you paid for someone to bleed you brakes and they were spongy, why was there no choice?In both instances the bike was my only form of transport, so it needed to be working, hence why I ended up fixing it myself. And had I not being able to fix it myself, it would have gone back for said shop/s to do the job. And only because it was brought up a few posts ago, as bleeding the brakes was only part of the work being done. I did get a reduction in the bill due to the brakes being spongy in both instances. But as the cable-tie method work both times and has always worked in the past, I will continue to plan ahead when working on a brake systems so I can use said method as a backup plan. Back on topic, lets wait and see how Bikebud gets on with his bike. [/quote] What I find very puzzling, is you went somewhere else and they did they exactly the same. It's a matter for you mate but something is very wrong here, one getting it wrong but two? Chances are there's something else at fault here. I would in all seriousness suggest you get your system properly inspected either you've been extremely unlucky or there's another issue, spongy brakes will not correct themselves and will only get worse over time, depending on how you ride and the way ABS works, it can speed up the process. What you've not said is, were they spongy before the bike went in for whatever it went in for, service I assume. Or did they came out spongy after they'd worked on it? Brake bleeding/fluid change isn't a annual task just inspection, on a GSF it's replace every 24mths, is the fluid past 24mths? Personally if that was my bike it would have gone back within minutes of riding the bike and I'd have insisted they were re-bled, as the bike was given back to you in an unsafe manner. As such they would be required to either correct it at once or supply you with a bike or cover costs until such time as they could correct the work. If they refuse, trading standards and take the bike elsewhere, then sue them through the small claims court for the corrective work and any bike/car hire and public transport expense if any. Most stealers would have just rebled them it's not worth the aggro as bad brake work isn't defensible. In my experience even the worst stealers start taking notice once you start politely pointing out their legal responsibilities certainly when they get contacted by either trading standards, solicitor or summons from the court, the vast majority pay up almost instantly. Re: FZ1 2nd Generation Brakes upgrade - b1k3rdude - 08-07-20 (08-07-20, 08:54 AM)Gnasher link Wrote:
Re: FZ1 2nd Generation Brakes upgrade - b1k3rdude - 08-07-20 (22-06-20, 07:17 PM)Bikebud link Wrote: I bought a 2012 FZ1 S ABS a few weeks ago. I'm loving the bike, but not very impressed with the brakes.Got an update for us fella..? Re: FZ1 2nd Generation Brakes upgrade - Bikebud - 21-07-20 Update: Also another thing to try and I had to do this on my ABS Bandit GSF 1250 after it was serviced by a shop was pump and cable-tie the brake lever back to the bar for 2 evenings. The brakes on my 1250 are now as sharp as the brakes were on my FZS. [/size] I've done the cable tie method and it has certainly made an improvement to the brakes. I pumped and tied the lever for about 10 hours, and noticed that it got a bit firmer, and did it again for about 48 hrs, and the lever is much firmer now, I got a more instant response abd better feel, and the lever doesnt pull all the way in. It seems the mechanic who serviced the bike before i bought it, did a terrible job bleeding it. Thanks for the tip b1k3rdude. Gnasher, I got what you are saying. I'm defnitely a novice DIYer, and brakes are not something I'm ready to mess with. I just needed a quick improvement to the brakes, before I take it to a professional to install braded lines and hopefully bleed it properly this time. But this will have to wait till winter. The brakes are good enough now. Re: FZ1 2nd Generation Brakes upgrade - b1k3rdude - 21-07-20 (21-07-20, 08:54 AM)Bikebud link Wrote: I've done the cable tie method and it has certainly made an improvement to the brakes. I pumped and tied the lever for about 10 hours, and noticed that it got a bit firmer, and did it again for about 48 hrs, and the lever is much firmer now, I got a more instant response and better feel, and the lever doesn't pull all the way in.Nice to know this trick now works on another bike with ABS, so for me thats GSF1200/1250 & FZ1. If you use a re-usable cable tie you could just do it for a 1/2 more nights and get it as solid as possible. Yes and no, thats 4 (3 for me) different shops all have issues bleeding the brakes on an ABS bike. Seems shop mechanics can learn from us home Diyr's. Back to your calipers, did the previous mechanic do a full service on them? as in remove & clean the seals(check if any needed replacing), polish the pistons and give brake pad bay a once over with a brass brush? I ask because when I got mine done on the 1250 it made a massive improvement to the feel of the front brake. Re: FZ1 2nd Generation Brakes upgrade - Bikebud - 21-07-20 Unfortunately I dont know exactly what the mechanic had done. I put a deposit on the bike just before the lockdown, on the condition that it gets a full service before I buy it. Lockdown happened and communication with them became difficult, so evently I had the bike delivered to me (without seeing it), and the guy who had serviced was still not back to work, so they could not confirm the exact work that was done, and had no service sheet. At least they did confirm that they checked the vave clearance ![]() I think all what they did on the brakes was replace pads and fluid, but not a full service. That will have be a winter project. |
