Battery losing voltage = dead? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Battery losing voltage = dead? (/showthread.php?tid=81580) Pages:
Re: Battery losing voltage = dead? - Gnasher - 15-04-20 (15-04-20, 03:14 PM)Farmboy81 link Wrote: due to some law (which I can understand, but would have been a bit of a bugger) Because a few tossers have taken to throwing it and other acids over ladies who dump them. :evil Re: Battery losing voltage = dead? - mtread - 15-04-20 Quote: One thing I did spot that I hadn't considered was that when buying the standard lead/acid battery, most places send them empty due to some law (which I can understand, but would have been a bit of a bugger), so I've got a shiny new Motobatt AGM battery on the way for less than the suggested L/A one!I thought they now send them full, and sealed (for the very reason Gnasher said). They used to send them empty, with the acid in vials which you pushed into the cells. But as said, it was too easy to decant the acid into any other container. Re: Battery losing voltage = dead? - Farmboy81 - 16-04-20 It's a bit variable depending which site you're on, some say they're not allowed to send them filled and you have to take it somewhere to get it filled; some say sealed and tested (generally a bit pricier, naturally); while others don't mention anything about it at all. All in all, I figured buying the AGM was a safer bet, plus it's the one recommended on wemoto as an upgrade to the original, 11Ah v 7Ah and 140 CCA v 70 CCA. Re: Battery losing voltage = dead? - Gnasher - 16-04-20 Old style lead acid batteries are now sent 'dry charged' you have to get them filled by someone who's got a licence to handle high concentrates of acid. Basically, they charge them and remove the acid, they can only be stored like this for maximum of 24mths, so check the battery date if older return it. They're then refilled, left for approx 30mins, test voltage 12.5v or above it's good to go, below 12.5 charge it. |
