Carb problems or is it something more?? Fazer 600 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Carb problems or is it something more?? Fazer 600 (/showthread.php?tid=81376) Pages:
Re: Carb problems or is it something more?? Fazer 600 - His Dudeness - 23-01-20 (23-01-20, 08:14 PM)Gnasher link Wrote: The butterfly's being open more will increase the Hg reading, these should only be open when the throttle is twisted. With the throttle fully home the Hg reading is set via the pilot circuit only, each must be between 230- 250mmHg at between 1150 - 1250rpm, if the reading is too high the butterfly isn't in it's rest position. This could be due to a number of factors, bad assembly, worn/broken part/s or incorrect previous carb balancing.Great info thanks! I thought the vacuum in the intake manifolds would be strongest when the butterfly valves were closed that's why I said his butterfly valves might have been slightly open. Guess I had it backwards :lol One more question when you're doing carbs do you set the mixture screws first using the reading on the vacuum gauge, then balance the carbs using the balance screws? Re: Carb problems or is it something more?? Fazer 600 - darrsi - 23-01-20 (23-01-20, 08:14 PM)Gnasher link Wrote: The butterfly's being open more will increase the Hg reading, these should only be open when the throttle is twisted. With the throttle fully home the Hg reading is set via the pilot circuit only, each must be between 230- 250mmHg at between 1150 - 1250rpm, if the reading is too high the butterfly isn't in it's rest position. This could be due to a number of factors, bad assembly, worn/broken part/s or incorrect previous carb balancing. Something that just caught my eye, you say 4-3 first, is there any particular reason for that order? Re: Carb problems or is it something more?? Fazer 600 - Gnasher - 24-01-20 4 is where the TPS is, as I said it's the datum just where I start. That said as mentioned the datum has nearly always been moved, in which case I get the carbs pulling 240mmHg and then adjust to each other, which is the balancing act, once they're all pulling 230 -250mmHg and are balanced I check the TPS. If it's out I move until it's back in spec, it's now back as the datum, going forward this is where you start i.e. if this carb is pulling 230 -250mmHg at the start move 3 to match it and 1-2 to match 3-4. Better still but beyond most owners and stealers is a gas analyzer attached to the downpipe. Re: Carb problems or is it something more?? Fazer 600 - YamFazFan - 25-01-20 On average, how often would you expect the carbs to require rebalancing? Re: Carb problems or is it something more?? Fazer 600 - Gnasher - 26-01-20 They shouldn't need totally rebuilding, short of a few 100k. They only wear short of that due to lack of maintenance that being, change of air/fuel filters, keeping the linkages clean and lubed and too much fiddling by people who have no idea of what they're doing. The amount of carb issues and damaged I've seen due to owners/stealers would stagger you :eek You can get the odd diaphragm degrading but it unusual in my experience. I see bikes I've been looking after for 30 plus years, some of these are 80k plus bikes still running perfectly on the original crab internals. Re: Carb problems or is it something more?? Fazer 600 - Disorderlypunk - 27-01-20 i proper balancing is always worth the money - especially after a rebuild - mine were out by a mile once i finally got the carbtune a few years ago a bench balance can be close but a proper job is always a benefit Re: Carb problems or is it something more?? Fazer 600 - darrsi - 28-01-20 (27-01-20, 07:30 PM)Disorderlypunk link Wrote: i proper balancing is always worth the money - especially after a rebuild - mine were out by a mile once i finally got the carbtune a few years ago I would hazard a guess that a lot of people don't even know what a carb balance is. When i first used my CarbTune kit not only did it make a big difference in general running, but it was kind of satisfying the fact i'd done it myself. Maybe it could be improved even more if done by a shop, but as long as i made sure all other related components were in good shape before giving it a go, like plugs, filters, TPS, etc, then i was more than happy with the results. Re: Carb problems or is it something more?? Fazer 600 - Dman2019 - 17-05-20 Thanks all for your advice, had 3 test rides now and it all seems to be back to normal. I readjusted the pilots back to factory settings and retuned the carbs and it seems fine. I tested the electrics and changed the ht caps, leads and regulators, when i put a multi meter over them there seemed to have different reading, thought its better safer than sorry Re: Carb problems or is it something more?? Fazer 600 - singhangad - 29-06-20 Sorry to hijack the thread I have the exact same issue on my bike with 150 000 miles on it. My question is what are you doing about it? Are you still just riding it or have you taken the head off to change the piston rings? I am thinking if its worth the effort or shall I just use it for as long as it goes. (21-01-20, 06:22 PM)His Dudeness link Wrote: I have a bike with low compression from worn rings/cylinders. The symptoms it's showing are it's hard to start when cold, it's down on power and top speed and it has a lot of blow-by into the crankcase. It's hard to start when cold however if you put a little oil in the cylinders it start instantly because the oil is sealing the cylinders and bringing the compression up. After it starts it runs well, it has no hesitation or spluttering anywhere. I think in your case it seems more likely that you had a spark issue after cleaning the engine, then later down the road you had a carb issue and you did some carb work and either it didn't fix the problem or it made the problem worse. Re: Carb problems or is it something more?? Fazer 600 - Trebor69 - 15-08-20 (16-01-20, 08:03 AM)darrsi link Wrote: You never mentioned the TPS at all in all of that (Throttle Position Sensor). Thanks for this, mine was reading 10000........may be able to smooth out the idle now
