Kill switch or ignition key - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Kill switch or ignition key (/showthread.php?tid=80678) Pages:
Re: Kill switch or ignition key - Grahamm - 16-04-19 (15-04-19, 06:39 AM)darrsi link Wrote: Eh? On an FZ6, the headlight switches on when you start the engine. If you hit the kill switch, the headlight will remain on until you turn the key off. Re: Kill switch or ignition key - darrsi - 16-04-19 (16-04-19, 12:05 AM)Grahamm link Wrote: [quote author=darrsi link=topic=25155.msg296417#msg296417 date=1555306786] On an FZ6, the headlight switches on when you start the engine. If you hit the kill switch, the headlight will remain on until you turn the key off. [/quote] Needs to be renamed a "Still Alive Switch" by the sounds of things! Re: Kill switch or ignition key - His Dudeness - 16-04-19 (15-04-19, 01:08 AM)Grahamm link Wrote: I used to use the kill switch and switch the key off as the last thing I did, until I discovered that, of course, it leaves the headlight on.If you started it in quick succession it'd be flat because of the starter motor not the bulbs. 700W vs 55W Re: Kill switch or ignition key - Freck - 16-04-19 I always use the key, mainly because of my other bike, a Triumph Daytona. There’s a quirk with them where damage has been known to happen to the ECU because of using the kill switch. When using the key a relay is activated keeping power to the ECU allowing a shutdown sequence to occur. This doesn’t happen using the kill switch which cuts power immediately, and has been known to cause irretrievable corruption of the ECU. Not something you really want, and would prove pretty costly. :eek Re: Kill switch or ignition key - fazersharp - 16-04-19 (16-04-19, 09:21 PM)Freck link Wrote: I always use the key, mainly because of my other bike, a Triumph Daytona.Is that after a build up over time or can it happen at any time from just one switch - if so I would be inclined to glue it on. Re: Kill switch or ignition key - His Dudeness - 16-04-19 (16-04-19, 09:21 PM)Freck link Wrote: I always use the key, mainly because of my other bike, a Triumph Daytona.So you turn the key off and a relay gets powered up to protect the ecu? That seems like they knew there was a problem and they came up with a work around instead of fixing it. Can it happen if you stall it or put the side stand down? Re: Kill switch or ignition key - Flooky - 17-04-19 I just stall it in gear, than sidestand then key and lock.dunno why. so its in gear I spos. |
