Chain tension/wheel alignment - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Chain tension/wheel alignment (/showthread.php?tid=80547) Pages:
Re: Chain tension/wheel alignment - daviee - 09-03-19 (09-03-19, 01:35 PM)fazersharp link Wrote: [quote author=daviee link=topic=25024.msg294190#msg294190 date=1552123192]I remember on my old Suzuki GS 125 on the way to Peterborough bike show, I lost my rear axle nut and stopped and pulled up i piece of wire from a hedge and wrapped it around the thread and carried on. Seems nuts thinking about it now and how could I of carried on - there and back [/quote] done the same on my ap50 but their is a huge difference in power i doubt you would get away with it on a 600 [/quote]Ahh you know what - it has just come back to me. Well it was over 30 years ago. It wasn't the rear axle at all it was the swing arm bolt/shaft nut that I lost. Which makes more sense as the pulling forces are different. [/quote] difference with the wee suzuki is the back sprocket carrier bolts on to the swing arm separate from the spindle so that you caan remove the rear wheel without touching the chain or adjuster great idea also stopped forces of the chain moving the wheel Re: Chain tension/wheel alignment - F4celess - 11-03-19 (09-03-19, 07:22 AM)darrsi link Wrote: As daft as it sounds it can simply be that it was fitted unwittingly by a left handed person! Agreed. ![]() The 2nd point you made about the cable drum reeling, reminds me of the days I flew big Powerkites, and reeling up the flying lines. If you happened to hold the Bar with the opposite hand on the previous outing winding/unwinding, you ended up with 4 x 25metre lines all tangled and then had to spend a further 30+ minutes fixing the 'birds nest' before you could fly... all while your 13+ metre wide powerkite was trying its best (on its own) to take off in the wind.... also the embarrassment of having your mates out and flying already, while you were grounded working on your lines! :\ :lol Re: Chain tension/wheel alignment - His Dudeness - 09-04-19 (07-03-19, 07:47 PM)F4celess link Wrote: Hello all,It's a bit late now but I saw another good tip to prevent this. If you pull the slack side of the chain up towards the swingarm as you're tightening the axle bolt. That should pull the adjusters forward and seat the covers in the swingarm |
