Quickshifter - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Quickshifter (/showthread.php?tid=80263) Pages:
Re: Quickshifter - CatalinU - 14-06-20 I did pull the trigger and installed one from Healtech Re: Quickshifter - Kenbob - 16-06-20 What do you think of it and was it an easy install. Re: Quickshifter - essiec - 28-06-20 Didn't have one on my KTM 1190 Adventure but did on my 790 Adventure and can say it was fantastic. Definitely an improvement with a pillion as there's no rocking when you have to roll the throttle with no QS - just keep the throttle wide open and change up, smooth as silk. What it doesn't like is changing up on part throttle, as it does clunk into gear. Best to only use it changing up from 2nd and above. 1st to 2nd is clunky anyway. If you're on part throttle just change as normal. But going up motorway slip roads at full throttle through the gears is addictive..... Re: Quickshifter - killerwhaleTRX - 28-06-20 (28-06-20, 10:27 AM)essiec link Wrote: Didn't have one on my KTM 1190 Adventure but did on my 790 Adventure and can say it was fantastic. Definitely an improvement with a pillion as there's no rocking when you have to roll the throttle with no QS - just keep the throttle wide open and change up, smooth as silk.Mine actually adapts the timing of changes depending on where you are gearwise and revrange, so very smooth all over. //M Re: Quickshifter - coffee - 28-06-20 (24-02-20, 07:35 PM)VNA - BMW Wank link Wrote: Anyway, last year I test rode an MT10, a CB1000R and a R1250R. Both the MT10 and R1250R had quick shifters. Don't you think however smooth and used to it you are changing without the clutch puts wear on some parts of the box? I would have thought just fanning the lever and dropping the revs a gnats' would be a far kinder way of going up the box,then again if you've had no problems doing it fair enough,I personally do it if I'm going for it through the gears but not as a constant thing,only my opinion .
Re: Quickshifter - VNA - 06-07-20 Quote:Don't you think however smooth and used to it you are changing without the clutch puts wear on some parts of the box? I would have thought just fanning the lever and dropping the revs a gnats' would be a far kinder way of going up the box,then again if you've had no problems doing it fair enough,I personally do it if I'm going for it through the gears but not as a constant thing,only my opinion .It’s how I’ve been doing it 25 years or more. I can’t see how it can do any harm. I also often go down the box without the clutch at low speed. I do wonder however, if gearbox issues will become more common now that we are in the age of the quick shifter. The two I have tried were crude compared to an old-fashioned clutch-less change. I just don’t get what all the fuss is about quickshifters. Re: Quickshifter - Papa Wheelie - 28-07-20 Have the Healtech Easy installed on 1st Gen FZ1. Advantages include less clutch wear, Quicker smoother upshifts and downshifts gears 3-6 and 6-3. Comes with a bypass plug that allows disabling or for testing. About a 1 hour install tapping into the coils under the tank routing and securing wires to the ECU placed under the seat and making sure the sender is firmly attached to the shift lever bolt with the special compression washers in place. Disadvantages include learning to ride without touching your shifter as any tap even from a bounce can momentarily cut power and if this occurs at the same time as manually clutching it can result in a missed shift at higher RPM then a lurch forward as you realize you are accelerating still in a lower gear. After learning to shift more precisely and firmly without resting on the lever the quickshifter becomes a breeze to use. 1st+2nd gear quickshifts up or down are very harsh and not recommended if you experience this as the manual says then to avoid them. You must have the transmission under load (meaning accelerating or constant throttle) to clutchless shift or you will crunch gears. Once programmed and understood the Healtech Quickshifter Easy is like butter shifting at full throttle like an automatic transmission up and down. Saved me 3/10 in my quarter mile drag times and adds alot of enjoyment and smoothness for spirited clutchless street riding |
