Clutch biting point issue, worn clutch basket? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Clutch biting point issue, worn clutch basket? (/showthread.php?tid=79726) Pages:
Re: Clutch biting point issue, worn clutch basket? - Hugh Mungus - 05-06-18 Sounds like the cheap levers to me. The only way to know for sure is to swap the clutch lever back and see if the problem occurs immediately. Re: Clutch biting point issue, worn clutch basket? - b1k3rdude - 07-06-18 (05-06-18, 06:52 PM)unfazed link Wrote: Check the pivot hole in the old lever you removed and see if it has elongated.Hole was fine (05-06-18, 06:59 PM)Hugh Mungus link Wrote:
Re: Clutch biting point issue, worn clutch basket? - Gnasher - 08-06-18 Glad you sorted it mate It's rare FZS1000's clutches fail with normal use, these adjustable levers are often a source of problems :thumbdown Re: Clutch biting point issue, worn clutch basket? - b1k3rdude - 08-06-18 (08-06-18, 09:17 AM)Gnasher link Wrote: these adjustable levers are often a source of problemsI have medium or size 9 hand and I find the position and biting point of the stock lever to combersome for commuting, so I need span adjustable - I just dont want to be paying £££ for a pair of these fucking things like seems to be the case most of the places I looked. Even the 'better' one I have now from memory cost me £65 second hand off a fellow foccer. Just which there was a comprehensive review/compare of some of the various makes.. Re: Clutch biting point issue, worn clutch basket? - NorthWestern - 08-06-18 I bought a Chinese copy of this: https://www.t3-racing.co.uk/products/brembo-style-clutch-lever Was £15 delivered. Put 30k miles on with it, no issues and was adjustable, levers feel really nice etc. Matched the master cylinder I had too! The only downside is there is no provision for a switch so I just bridged it. Edit: just looked and you can now get them for £11. They do say they come with a switch (mine didn't) but it looks like they have put the switch in the threaded span adjust hole. So you can either have a switch or the ability to adjust the span. I left mine std, was better than stock lever for reach. Re: Clutch biting point issue, worn clutch basket? - slappy - 08-06-18 When I had my gen1 1000 I fitted an adjustable span clutch lever from a Kawasaki 900 ninja. It was cheap to do and looked " factory", I am fairly sure a few other people had done it before me and I just copied them, you had to use the Kawasaki perch as well. Remembered now it was the clutch lever from a Kawasaki ZX9 , C1 or C2 model. Re: Clutch biting point issue, worn clutch basket? - b1k3rdude - 15-06-18 Well it turns out its not completely gone or fixed, which is when I realised two things -
