Bizarre EXUP self-test behaviour - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Bizarre EXUP self-test behaviour (/showthread.php?tid=79603) Pages:
Re: Bizarre EXUP self-test behaviour - roxburd - 01-05-18 (01-05-18, 09:43 PM)unfazed link Wrote: The Mounting plate can wear on the inside and can cause side play and a bit of noise, however it does not effect the operation of the valve. Mine is worn enough and has a ridge, but works fine. (40000miles). Last time mine was rattling it was because I had to much slack in the cables. D'Oh! Too much slack in cables - that'll be the first thing to check then! Thanks, I should have thought of that. Haynes specification says 1.5mm cable free play (but not how it's measured) but the text says half a turn on each of the adjusters - I guess it's just a matter of finding the sweet spot really. Re: Bizarre EXUP self-test behaviour - robbo - 02-05-18 I'd have thought an engineering shop could make bushes for less money, if either of them was the problem. Even have them custom made to factor in any wear. Just a thought. Re: Bizarre EXUP self-test behaviour - unfazed - 02-05-18 Unfortunately they are not a normal steel or brass bush. Last time we had to cut one that was seized we found it to be an extremely hard brittle item. We cold not determine what it was made of. They do come up occasionally on eBay as new old stock for around £25. Re: Bizarre EXUP self-test behaviour - celticbiker - 02-05-18 I should imagine they are made of phosphor bronze. Re: Bizarre EXUP self-test behaviour - unfazed - 02-05-18 Did not think so any Phosphor Bronze bush I ever saw were Bronze in colour the one in the EXUP has a polished steel look Re: Bizarre EXUP self-test behaviour - NorthWestern - 02-05-18 IIrc They are ceramic |
