Fazer 600 not starting - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Fazer 600 not starting (/showthread.php?tid=79103) Pages:
Re: Fazer 600 not starting - Disorderlypunk - 08-01-18 nice trick with the engine oil hopefully it will loosen off a ring if its stuck as they all shot up it kind of points more at the rings than the valves which is where i would have instantly thought might be concerned about a large amount of wd40 getting through the ring gaps and mixing with the oil but im guessing it hasnt had an oil change in a while anyway so no problem there really Re: Fazer 600 not starting - alex9576 - 10-01-18 Hopefully I can get it started so i can check the gearbox just for piece of mind before it gets striped down, ill let you know how i get on.
