Bike doesn't turn on / no lights - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Bike doesn't turn on / no lights (/showthread.php?tid=79037) Pages:
Re: Bike doesn't turn on / no lights - tommyardin - 19-11-17 (19-11-17, 01:07 AM)bandit link Wrote: Not convinced myself that it's just water damage as plugs are melted,why is there a 25 amp fuse where a 10 amp should be. [img alt=Shocked]http://foc-u.co.uk/Smileys/efocicon/shocked.gif[/img] Hi bandit, I guess it could just be that the connection was corroded slightly either by a water ingress or corroded because of a loose connection arcing and sparking. A loose joint like that causes burning and blackening of a contact, that in turn causes more arcing and the fuse to blow and the previous owner got over the blowing fuse by shoving a heavy fuse in line, that in itself would seem to cure the problem until the joint became so unstable that it melted the connector. My guess would be it had nothing to do with a water ingress but a loose arcing connection. IMO :rolleyes Re: Bike doesn't turn on / no lights - Disorderlypunk - 20-11-17 holy crap what happened there - not been on this post in a while expecting it to be a simple thing like a loose connector that just needed you to find but bloody hell thats an impressive failure does look like it could have been corrosion on the connections causing a smaller contact patch causing excessive heat and in turn smouldering connector block but who knows - a bit of trimming and the correct type of connector and you will be laughing again i will repeat this bit - CORRECT TYPE OF CONNECTOR BLOCK i do that because there are certain types of block i see that never belong in a bikes wiring loom ![]() Re: Bike doesn't turn on / no lights - Diogo.fps - 21-11-17 Thank you to everyone who's taking the time to explain, as you can see i'm no expert :b But I'm learning bit by bit (20-11-17, 12:39 AM)Disorderlypunk link Wrote: i will repeat this bit - CORRECT TYPE OF CONNECTOR BLOCKI was intending to try to find the same type of connector block that the fazer originally uses. But can you tell me what's the problem with that connector anyway? Re: Bike doesn't turn on / no lights - Disorderlypunk - 21-11-17 it is just a bodge pure and simple and i love a bodge here and there to work as a fix untill it can be done properly (i use a lot of them) but that connector block was designed for use in houses and is an unsightly thing on a bike a OEM connector is often not available and cost a fortune from aftermarket suppliers and i rarely use them but a crimped bullet/spade connector is the way to go as they are made for vehicles and not your house [edit] assuming you are meaning the block i pictured - there is nothing wrong with the oem block its unfortunate that yours had a failure that is rare to see Re: Bike doesn't turn on / no lights - celticbiker - 21-11-17 (21-11-17, 02:09 AM)Diogo.fps link Wrote: Thank you to everyone who's taking the time to explain, as you can see i'm no expert :bI was intending to try to find the same type of connector block that the fazer originally uses. But can you tell me what's the problem with that connector anyway? [/quote] A simple 2 pin waterproof connector can be had here. https://www.ebay.co.uk/itm/1-11-WAY-PIN-6-3mm-ELECTRICAL-MULTI-PLUG-CONNECTOR-TERMINAL-BLOCK/151430793986?hash=item2341fa8b02:m:mKBHjPHLBRnoNP_YZtXs2dg But you can also get waterproof ones here http://www.ebay.co.uk/itm/2-Way-Pin-Car-Auto-Waterproof-Wiring-Cable-Electrical-Multi-Connectors-Block/271683539695?hash=item3f4199d2ef:g:0skAAOSw2XFUbGkZ But do ensure the correct load rating before buying. Re: Bike doesn't turn on / no lights - tommyardin - 21-11-17 As Celtic showed they are the DOGS BOLLOCKS. Either that or solder and heat shrink, but the connectors that Celtic recommended are better because ease of undoing should the need ever arise (Probably Not) but it is a possibility |
